Old 04-15-2005, 06:34 AM
Judge not's Avatar
Judge not Judge not is offline
Hey Jyd, When I head the heads off I put #1 piston at T.D.C. and when I reassembled the motor and installed the damper the line was at tdc so I believe my timing marks are ok. The performance hasn't improved with advancing timing, but I will try some more advance. This car idles way to smooth for this cam. If I installed it a tooth off would it idle this smooth? Maybe I have it retarded, like me
"A government big enough to give you everything you want is a government big enough to take from you everything you have." Gerald Ford
“The problem with socialism is that you eventually,
run out of other people’s money.” - Margaret Thatcher
