Old 04-07-2005, 11:59 AM
satman's Avatar
satman satman is offline
suadboy, this is the description in my assembly manual on CD.
1. Remove the head restraint for seat back
2. Using a flat bladed tool, carefully snap off seat back lock button and escutcheon assembly and remove the two screws securing seat back panel to lock assembly (these are behind the push button)
3. Tilt seat back forward and remove three screws securing bottom of seat back panel to seat back frame.
4. Pull bottom of seat back panel outward and lift panel upward from upper retainers: then remove panel from seat back
5. To install seat back panel, reverse removal procedure. When snapping on seat back lock push button and escutcheon assembly, make sure assembly is installed right side up with contour of side flanges matching contour or seat back.
