Old 05-17-2005, 10:19 AM
Scode68 Scode68 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by BigDan3131:
The allmetal is a very easy to use product .... I feel comfortable sanding it to is with 80 grit before primer.With all metal you can go all the way to 220 grit and it hold primer great with no bleed thru. </div></BLOCKQUOTE>
I’m trying to sand it with an IR-315 in-line sand and I’m having problems. Seems to be loading up the paper. It should be cured well because the left over got rock hard. I mixed it lick they said, 12-15 drops of hardener to about a golf ball size glob. Could the sander be creating too much heat or something? I think it was mixed pretty well but it will get little globs that build up on the paper within 10 seconds of sanding.
