Old 03-30-2005, 07:37 AM
Billy177's Avatar
Billy177 Billy177 is offline
allright, and the final; question will a performer rpm clear the hood of a 1970 gto
70 GTO
462 E-Heads TKO-600 9-Inch/3.60's
Old 03-30-2005, 07:51 AM
GoatDr GoatDr is offline
Yes, it will clear. Even the Torker2 clears with a spacer on my 70 goats.
GoatDr
Old 03-30-2005, 08:49 AM
73ta's Avatar
73ta 73ta is offline
I had to take 0.060" of of my Performer RPM to get the ports to match. Not only cost me $160, but took forever to find a machine shop with the capability to do it. This is mounted on a stock height block with new Edelbrock heads. You would think Edelbrock would be able to make a better match than this with their heads.
Old 03-30-2005, 10:23 AM
form406's Avatar
form406 form406 is offline
id measure the height of the rpm and double check...wouldnt clear my formula hood...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
Old 03-30-2005, 01:59 PM
SHould be not proble, on hood clearance . A friend has one on his 71 GP hidden under the factory air cleaner and painted to match the motor.
