Old 04-08-2005, 06:28 PM
BN's Avatar
BN BN is offline
Asked this in electrical but thought one of you might know. My gas gauge on my 72 Lemans that always worked well went to full and stayed there . The tank's about half full. Any ideas?
BN's Avatar
BN BN is offline
Old 04-09-2005, 06:27 AM
lethal-428-lemans's Avatar
Check for good ground.
Patrick
Old 04-09-2005, 12:05 PM
BN's Avatar
BN BN is offline
Can this be checked w/o lowering tank?
Old 04-09-2005, 01:38 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Yes, Bill.
Locate the sending unit wire connection, I believe it's inside the trunk. With the igntion in the "run" postion, ground the wire - it should go way past full. Disconnect the ground but DO NOT reconnect the wire to the harness - it should go past empty. If these test are OK, your problem is within the sender. If not, then you need to trace your wiring and check or replace the guage itself.
Good luck!
Regards,
"455HO" Lloyd
Old 04-09-2005, 02:53 PM
BN's Avatar
BN BN is offline
Boy doesn't this sound like fun. Wish I lived in Texas, I'd take it to bellair auto center and let them worry about it,,,Ha Ha
Old 04-10-2005, 05:00 PM
Phil from Canada Phil from Canada is offline
My 72 lemans GT had the same problem. I located the wire on top of the back of the fuel tank. It is easily accessable by lying on your back under the fuel tank. I found the wire had come off the connector, that connects to the fuel tank. I cleaned it up and rewired it. Works great now.
Phil
1972 Lemans GT with 1977 W72 TA engine and manual transmission
Old 04-14-2005, 01:32 PM
BN's Avatar
BN BN is offline
Found the wire coming from sender. It goes about a foot and then stops. (It was splaced and came apart). I can't find the other end. Can anyone tell me where the wire goes from exterior into the interior so I have a better idea where to look?
Old 04-14-2005, 03:33 PM
Check along the rear cross member and inside the trunk under the latch. I'll look to see if I have any wire info if I do I will post it.
Patrick
Old 04-14-2005, 03:43 PM
Here is some info that may help.
Patrick
Old 04-14-2005, 07:05 PM
BN's Avatar
BN BN is offline
Problem solved, Thanks for the help.
Old 04-15-2005, 04:58 AM
LisaJ LisaJ is offline
Send a message via Yahoo to LisaJ
Thanks for posting that image from the service manual lethal-428-lemans. My gas gauge never goes past 1/4 full (but it will go down normally from there). Now I have a clue how to check the problem.
~LisaJ in Massachusetts
Old 04-15-2005, 06:46 AM
Glad it could a couple people.
Patrick
