Old 02-18-2003, 04:07 PM
bills goat bills goat is offline
I hate to bring this up again,but i just cant get it right. I converted to rally gauges. I have read all the posts about swaping out two wires "TYPICALLY: swap 5 and 7 GEN and FUEL wires" which i did but no luck.Here is something i did during the restoration i changed the front wiring harness to a GAUGE HARNESS dose this mean i dont need to swap 5 and 7 GEN and FUEL wires ?
I am using the gauge type sending units for oil & temp.can anyone help me ???
Old 02-18-2003, 05:02 PM
Huss Meister Huss Meister is offline
Hey Bill..I havent messed with the gto harness but ive done old camaros....which harness is the guage harness under hood..or dashboard harness? or both if both you shouldnt have to do anything...if not follow the contact from the fuel guage and see if the pug contacts are meeting it..when you plug the cluster in
Old 02-20-2003, 07:15 AM
Thanks for your reply.the wiring harness under the hood is for rally gauges.the under dash is the old idiot light harness.dose that still mean i need to swap wires at the gauge cluster???
Old 02-20-2003, 10:39 AM
Held for Ransom's Avatar
The engine compartment harnesses are the same. The only differences are transmission type and if it was Ram Air or not. Yes, the wires will still have to be swapped.
So long, farewell.
Old 02-20-2003, 10:58 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Also what year car is this, as i believe the 2 wire swap is for 69-71 clusters, and 72 has a different procedure. So if you have a 69-71 car and gauges from a 69-71 then yes the tan and brown get swapped, its very easy, just use a small screwdriver to push down the retaining arms in the plug and pull the wires out. then bend the little arm back up again carefully and reinsert them in the other hole. When its backwards, your gas gauge will act like a volt meter, going up when its running and your gen light will be on brighter or darker depending on your gas level. Let us know if you get it.
P.S. If you are just trying to get this working by plugging it in with the dash out, you need to ground the gauge pod or they wont work at all.
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 02-20-2003, 12:26 PM
See my reply in:
70 GTO wiring diagram for all...... Large, but useful!
In this section.
HIS
"tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs
11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs
12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
Old 02-21-2003, 01:48 AM
He has a '70 GTO as indicated in this post. http://forums.performanceyears.com/g...1&m=7246001911
So long, farewell.
Old 02-21-2003, 12:13 PM
grandville455's Avatar
I just got a total gauge pod for my 74 grandville which now uses idiot lights does that mean i have to change my harness in the engine compartment and dash too ? there not the same?
Grandville455
Darby
M/T 275/60 ET SS Drag Radial
Old 02-21-2003, 12:49 PM
grandville,
no. Just means you have to move some wire positions within the Harness' gaugepod connector.
HIS
Old 02-21-2003, 04:06 PM
Thanks to everyone who helped I FINALY GOT IT. I was thinking the swapping of the wires had to do with the oil/temp gauges, I now see the swap is to get the fuel gauge working correctly. Now it makes sense to me.Thanks again for going over this for me...
Old 02-21-2003, 04:29 PM
HIS:
What wires will i be moving?
Grandville455
Darby
Old 02-21-2003, 04:34 PM
Forgot to say gauges are from a 75 bonnie does any of that matter or still have to switch?
Grandville455
Darby
Old 02-24-2003, 07:42 AM
Grandville,
Easiast if you have access to a B series schematic from a '74 Pontiac Service manual.
