Old 08-09-2005, 09:18 AM
Cool Forged Cranks
I saw BOP's new catalog this weekend at Norwalk.
Mark said look on the back cover.
FORGED CRANK available soon! And probably a reasonable price.
WOW, just in time for me.
Thanks, BOP!
Old 08-09-2005, 09:40 AM
Robert C.'s Avatar
Robert C. Robert C. is offline
Talking
AllPontaic.com and BOP will be making anouncement soon! And yes, we are working together on this project. The stroke will be from 4.00 to 4.500.
Stay tuned.
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 [email protected]
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
Old 08-09-2005, 10:19 AM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
Thumbs up
*gets in line*
Old 08-09-2005, 10:42 AM
slowbird's Avatar
slowbird slowbird is offline
That is great news and bad news for me. Do I go ahead with my engine plans or put things on hold now until the cranks become available? These really are good times to be in the Pontiac hobby.
Old 08-09-2005, 12:01 PM
mikeb mikeb is offline
Where do I sign up? This is great news.
Old 08-09-2005, 12:19 PM
Robert C.'s Avatar
You can order from AllPontiac.com or BOP at a future date. Delv. is early spring. I will be kicking them in the butt to get them faster. Estmated price is $1,095.00 at this time. Material is 4130 forging, and Nitrided.
( Quoted from Wade at BOP)
2. The crank will NOT be cross drilled. It will incorporate the latest technology in crank oiling, scoop oil holes and straight shot oil timing. This process pressurizes at the low pressure part of the stroke and traps the oil wedge during the high pressure part of the stroke. Cross drilling forces the oil pressure to try and overcome combustion pressure of 1000 plus psi which and translate to 10,000 psi at the bearing. This force will push the oil right back out the journal and send it to another place in the crank. Straight shot traps the oil and it has no where to go but to the rod bearing. It is the best oiling system currently available for low or high HP motors at this time.)
As you all have seen, we at AllPontiac.com and BOP are going out of our way to produce the best race parts for a pontiac that have been ever made.
Get in line soon.
Bob C.
Boss Bird Funny Car
Old 08-09-2005, 12:21 PM
lemans411's Avatar
lemans411 lemans411 is offline
when will you start taking orders? do you have to pay in full or are you taking deposits?
-rob
Old 08-09-2005, 12:23 PM
Brian Baker's Avatar
Bob...why the cross drilling? I've read alot on the subject from Reher-Morrison and they strongly advise against it in most cases. I'll take mine with standard Pontiac drilling with the oil holes chamfered (wink).
Old 08-09-2005, 12:26 PM
cgeise's Avatar
cgeise cgeise is offline
Question Crank Info
Bob -- The info on the crank is great -- a couple of questions. Will they be available in both large and small main size and BB Chev rod bearing configuration? Your post indicated cross drilled -- there was a very good artical in the National Dragster by a major engine builder that was very much against cross drilling -- for a number of reasons -- Just some FYI for you guy's to look at. Will they be available in custom stroke sizes?
Old 08-09-2005, 12:28 PM
slowbird's Avatar
Will they be knived edge or anything like that or will they be just like the stock cranks but forged? I tried calling but no answer will try again later.
Old 08-09-2005, 12:39 PM
Robert C.'s Avatar
( Quote from Wade C.)
I changed this posts to reflect the correct information. 8-10-05 rjc.
They will have a semi knive edging done but not a full knife edge.
Bob C.
Boss Bird Funny Car
Old 08-09-2005, 12:52 PM
slowbird's Avatar
Will there be an option to not have it crossed drill for those that will be turning alot of rpm and making the hp? I hope you get a LARGE first shipment because I think they will be going fast.
Old 08-09-2005, 01:36 PM
slowbird's Avatar
What is the difference in 4130 steel and 4340 steel?
Old 08-09-2005, 02:15 PM
Originally Posted by Robert C.
This is from David Butler: Cross drilling will not hirt a low horse power motor. But will supply oil to the rods when the oil hole is oppsite from the oil hole in the bearing. This will save the rod bearings.
We are getting $500.00 down and the rest at shipping.
I would suggest that both you and David Butler call Mr. Reher to discuss it further at length. I'm just a layman, but I can understand what he means by the oil pump having to overcome centrifugal forces to provide pressurized oil to that extra hole. Given that most Pontiacs run 60-psi or less, I don't see this as a good thing. I'll have to dig up that article from ND and post it here (or perhaps Tiki' can?).
Define "low horsepower motor". The whole purpose of this crank is for those making in excess of 750-HP, is it not? I mean, it'll be a better bet over a cast in any application, but the cast cranks have already been proven to 750-HP reliably.
Old 08-09-2005, 02:53 PM
Talking
You can order from AllPontiac.com. Delv. is early spring. I will be kicking them in the butt to get them faster. Estmated price is $1,095.00 at this time. Material is 4130 forging, cross drilled and nitrated.
As you all have seen, we at AllPontiac.com go out of our way to produce the best race parts for a pontiac that have been ever made.
Get in line soon.
Nitrided.
"ide" = one molecule
"ite" = 2 molecules
"ate" = 3 molecules
Old 08-09-2005, 03:09 PM
455firebird1969's Avatar
Society of Automotive Engineers (SAE) is used in specifications for all high-grade steels used in automotive and aircraft construction...
Each SAE number consists of a group of digits...(normally 4, but not always)
The first digit represents the type of steel...(pricipal alloy element)
The second digit represents the percentage of the principle alloying element...
The last two or three usually, represent the percentage, in hundredths of 1 percent, of carbon in the alloy...
For example, SAE number 4130 indicates Molybdenum steel containing 1 percent molybdenum and 30 hundredths of 1 percent of carbon...
Here is the steel chart...
Carbon 1xxx
Nickel 2xxx
Nickel-chromium 3xxx
Molybdenum 4xxx
Chromium 5xxx
Chromium-vanadium 6xxx
Tungsten 7xxx
Silicon-manganese 8xxx
I hope this helps...
Old 08-09-2005, 03:13 PM
Nitriding is not part of the original alloy.
It's basically a process or 'coating' that makes the surface harder.
Old 08-09-2005, 03:44 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
A couple of clarifications on the forged crank deal.
1) The material will be a 4340 non-twist forging.
2) The crank will NOT be cross drilled. It will incorporate the latest technology in crank oiling, scoop oil holes and straight shot oil timing. This process pressurizes at the low pressure part of the stroke and traps the oil wedge during the high pressure part of the stroke. Cross drilling forces the oil pressure to try and overcome combustion pressure of 1000 plus psi which and translate to 10,000 psi at the bearing. This force will push the oil right back out the journal and send it to another place in the crank. Straight shot traps the oil and it has no where to go but to the rod bearing. It is the best oiling system currently available for low or high HP motors at this time.
3) The 3 inch main cranks will be available in 4, 4.25, and 4.5 inch strokes with 2.200 rod journals.
4) We are hoping to produce a 3 ¼ main but do not yet know if it will happen. If it does it will probably be available in a 4.250 stroke only.
5) Target price is $1095.00 but is not definite at this time.
6) The cranks will be gas nitrided, no induction hardening
7) Neither BOP Engineering or All-Pontiac.com are taking orders at this time
We will have more information soon so please be patient. With that said we are pleased to be working together with Frank and Bob to bring high quality racing parts to the Pontiac community.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 08-09-2005, 03:52 PM
Thank you for the clarification, Wade.
Old 08-09-2005, 05:40 PM
Nine Ninety's Avatar
Nine Ninety Nine Ninety is offline
[/QUOTE]
Bob C, That is consistent with the response I got from Mark at Norwalk. We definitely need the high speed oiling system as opposed to the factory style oiling system.
David Reher's article from National Dragster provides some interesting information on why cross-drilled cranks shouldn't be used. Check it out at:
http://www.findarticles.com/p/articl...7/ai_n14799082
