Just got my engine back together, again.
I decided to give the "Gutsram" a try. This intake needed lots of attention to make it fit. I also had a custom top made, the carbs sit at an angle so that the throttle bores line up with the port runners. This top is about half the weight of the stock cast top as it was cnc'd out of a piece of 6061 billet aluminium. If there is anyone that has used one of these that has any tuning information to share it would be appreciated (including the N2O fogger). I was also able to install my new timing chain set, with the torrington thrust bearing, that I got from Scott Simms of "Simms Performance". I must say that this is a quality piece and the directions that are supplied with it are clear and precise. Thanks Scott! Hopefully I will get the time to get this setup dailed in soon. Todd |
looks good, what's the combo?
1969 GTO Judge Ram Air III 1968 Catalina "Darkside" Vert! |
Hi Chris, 13:1 compression 475 (stock 455 block) Ported E heads Comp cams solid roller cam GRP rods Ross pistons w/ total seal gapless rings Eagle crank Gutsram w/ two 750cfm carbs and NOS annular discharge nozzles Todd |
Is this my friend Todd from Reno???
![]() Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Hi Ron,
Yes, it is I. With the new board my screen name now shows up as my login/user ID. I don't mind it so much, it will just take some getting used to. Todd |
Ron,
You have friends? Only kidding! The Intake looks Sweeeeeeet!!!! Rodney |
I have a Gunstram I want to try myself.
It's a stock block 455(464) KRE alumimum heads CNC ported UD solid flat tappet cam 249/259 @ .050 Presently runing dual AFB 750's on a Offie intake.. Just wondering how much I would loose on bottom end response/power..if any ?? Also want to go to 2" primary tubes on headers,,if I can find a set !!
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
60's man. The Gutsram is pretty tall and has large ports. It may stick the carbs thru your hood. I ran one for a while with both 750 AFB's and BG Demons but went back to my Bathtub intake because it made the same HP and was shorter and lighter.I tried 3 sets of Holley/ BG carbs and ran as fast or faster with my AFB's. The Bathtub with AFB's was 22 lbs lighter thsn the Gutsram with BG Demons.
I think what you need is a roller cam with about 276-280 duration and .650-.700 lift. Dave |
