Old 09-12-2005, 10:17 AM
GTOster GTOster is offline
Angry Need some help crossmember
Need some help I am redoing a 67 GTO I have cutout and replaced the full floorpan on the Pass. side No Problem!!!
On the drivers side I cut out the floor pan and found that the front crossmember is gone right where the body mount comes thur the frame about 3 inches the rest is fine I have purchased a 16" replacement part from PY my question is how do I get to the crossmember that connects to the back part of the rocker i dont want to remove the body from the frame just yet I wanted to weld the floor pan in before I lifted the body so nothing twists I welded a new trunk in so the metal back there is all good and all the body mounts are removed at this point
Is there an easy way or not so easy way to do this??
Can I lift just one side to get to it or will it twist???
Thank You in Advance
Paul
Old 09-12-2005, 09:03 PM
Kron Kron is offline
Not sure about your model year but I have a 69 lemans convertible with a shot floor and the body braces are rotted out where the meet the inner rocker.
Since the body brace on the 69 wraps around the frame the only way I can get at them is to lift the body off the frame, replace the braces (all 3 of mine are shot) and then complete the floors.
I made up some extra bracing for the car so things don't move while I'm seperating the body from the frame.
Tony
