Old 09-13-2005, 12:25 AM
hvirgen hvirgen is offline
Default Formula Steering Wheels - Types?
What are the differences between Formula steering wheels? I know about the early 2nd gens having a thicker rim, but what about the finish on the grip and metal? I've seen some with flat metal finish and some with anodize finish.I've also seen some grips that look like foam rubber instead of the leather wrap look.Is this just wear or was there a real difference?. I have a 72 and would like to get the correct wheel. Any help would be appreciated.
Old 09-13-2005, 11:49 AM
tdavidl's Avatar
tdavidl tdavidl is offline
this thread may help, sorry the pics don't show, i think you have to be a member & log in:
http://www.transamcountry.com/forum/...906&highlight=
this may help though i doubt it:
http://www.transamcountry.com/forum/...176&highlight=
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 09-13-2005, 11:01 PM
tdavidl
Thanks that helps, but does anyone have some steering wheel pics?
Old 09-14-2005, 11:25 AM
tdavidl's Avatar
i'll try to remember to post the pics i have (assuming i still have them) this evening. TAC is having site probelms & i believe they removed some of the pics from old topics.
Old 09-14-2005, 10:24 PM
Thanks,
I read someone on the net that the very first formula wheels in 1970 were actually hand wraped and sewn and that later in 1971 they were "formed". I've never seen a real early wheel so I also don't know what the finish was on the metal. I seen some supposedly early that have a wrinkle like paint finish.
Old 09-15-2005, 01:07 PM
tdavidl's Avatar
can't comment on the "wrap", i've never heard of that nor seen it. here are pics of mine which is suppose to be one of the original (early) types , so i've been told (see link above) :
Name:	DSC00498 (Medium).JPG
ID:	27219   Click image for larger version
Name:	DSC00499 (Medium).JPG
Old 09-15-2005, 02:02 PM
There were at least 3, possibly 4 different thicknesses of the Formula wheel from late '69 intro through '81. The earliest version was the THICKEST, a std shape biz card will roll all the way around the rim of a true FAT wheel leaving around a 3/8" gap.
The last aluminum spoked versions ('77 & '78 & some '79's) & the '79 & 80 (some '81) steel spoked versions, one can wrap a business card around the wheel, & one will come up with a 1/8" gap. Have over a dozen Formula wheels from this era & all measure the same.
Thinnest version was the steel spoked black textura painted wheels used on some '81 models. With this thinnest version, the ends of a std business card will touch. Ck out an original dark blue '81 Formula wheel if you get a chance. Dark Blue seems to be a color that for '81 was "super" thin. The chocolate brown wheels for '81 were not that thin. Have had quite a few of each.
Early wrapped Formula wheels, don't believe so. Have quite a few original FAT rim Formala wheels, earliast of which was original on a Oct '69 built '70 455 4spd GTO. This early '70 Formula wheel is identical thickness wise to the original Formula wheels off my '70 1/2 T/A, '71 Judge, '71 1/2 GT-37, & late '72 T/A.
Only original wrapped Formula wheels were the pacecar Formula wheels. TATA's & Indy pacecars got these. Have one & it needs restoring, there is a biz in Mesquite Texas that recovers them along with leather wrapped Vette wheels.
FAT soft Formula wheels...
Back in 1981, I pulled a really nice condition FAT wheel off a '74 T/A in local late model yard. Near flawless wheel, but was soft, & is to this day much softer than all my earlier FAT rim wheels. I believe it was made by another supplier OR injected out of different material. Over the years, have had quite a few soft fat Formula wheel cores that were in much worse shape. Years & years of exposure to sun & weather will soften up even an original hard FAT rim wheel, but the '74 wheel I have was def soft to begin with & so were others.
Hope this helps.
Old 09-16-2005, 12:56 AM
'ol Pinion head,
Thanks for the info, it really helps. Do you know if the metal finish was the same on all years? Or do they differ from year to year? I'm looking for a correct steering wheel for a 12/71 production date T/A.
Old 09-07-2008, 11:15 PM
pontorquer's Avatar
pontorquer pontorquer is offline
I picked up a 1976 Formula rally steering wheel today and was wondering if they were just as thick as the early ones or thicker than a 78, let say ?
Old 09-08-2008, 08:31 AM
FloridaFirebird FloridaFirebird is offline
My '73 has an anodixed finished spokes ( showing mostly the aluminum now) and I believe it to be original but I have seen some with a texturized paint looking finish that I was told was original also.
Anyone clarifiy this for hvirgen and me as well?
Thanks,
Old 09-08-2008, 05:45 PM
Baba O'Riley's Avatar
Baba O'Riley Baba O'Riley is offline
Who makes the best repro wheels for a '71, anybody know?
"A MAN IS ONLY AS OLD AS THE WOMAN HE FEELS."
-- Groucho Marx
Old 09-08-2008, 10:59 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
I think there is only one repro fat wheel out there. The one I got measured right on the thickness. The feel of them is a bit harder than the original wheels, and the grain they put in them is not correct but it can be carefully sanded out to look smooth like the correct original wheel surface and dyed with SEM landau black.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 09-09-2008, 12:26 AM
68bird400HO's Avatar
Hope this helps.
Based on the what I have observed, the soft fat wheels started in '73. All of the '70 to '72 wheels I have seen have had the "IC" code stamped in them and were pretty firm. The '73 and up fat wheels I have seen have all seemed softer, as you describe, and didn't have the "IC" code anymore.
Old 09-11-2008, 04:49 PM
Rockcrusher72's Avatar
Rockcrusher72 Rockcrusher72 is offline
Originally Posted by hvirgen View Post
tdavidl
hvirgen,
Here's some pics of the formula wheel in my '72 Trans Am. The build date on my cowl tag is 11B (second week of November). This is the original wheel to my car, at least that's what I was told. I don't have any reason to believe any different as almost everything else on the car is original and as you can see from the pics it's showing its wear from 36 years.
Edit >>> I should also add that my wheel is firm, I would not call it soft by any means. For instance you could not squeeze it and have it expand/contract within the tightness of your grip.
Sorry for the size of these, I don't know how to make them smaller...
Old 03-18-2009, 10:51 AM
Judge273's Avatar
Judge273 Judge273 is offline
Has anyone ever seen this type of wheel? It has a "4" molded in. It is a little thicker than 3 1/2" or very close to a business card wrap.
Mike/Illinois
Old 03-18-2009, 01:15 PM
Zirconia Zirconia is offline
The wheel looks to be mounted out of phase with the hub. I would say it is a late 73-76 era wheel.
Old 03-18-2009, 01:36 PM
Judge273's Avatar
Thanks zirconia, the hub is just screwed in to keep parts together for now.
Have you ever seen the "4" in these wheels before to tell late 73-76 or is it based on oPh reply?
Mike/Illinois
Old 03-18-2009, 03:23 PM
I see the 4, clearly. I can't explain it. That looks like the mold mark common to those. It could be just a "Jesus in your toast" phenomenon.
Old 03-18-2009, 04:14 PM
MescaBug's Avatar
MescaBug MescaBug is offline
I've got an early 'fat' wheel, late 1969 I should say. As you can see on the picture, the rim is very fat. And it's small in diameter. I love it.
Old 12-12-2016, 09:03 PM
ladytata's Avatar
ladytata ladytata is offline
I'm always curious and notice this. Anybody have any knowledge on these differences?
#1Red one is crinkled and has a number stamped on the inner metal circle. #2 has the gold spokes and the number 1 1 stamped in the circle. #3 came off an 80 and it is very soft grip , the car might of been an se. Now I notice that in the center some have 2 notches and some of my other ones have one. I'm assuming that a change in years.
ID:	442583   Click image for larger version
ID:	442584   Click image for larger version
ID:	442585   Click image for larger version
ID:	442586   Click image for larger version
