Old 09-30-2005, 04:27 PM
ventura7211's Avatar
ventura7211 ventura7211 is offline
While the stroker kits for a pontiac and chevy are about the same, the main difference is what you get for $1700:
Pontiac: cast crank, h-beam rods, name brand forged pistons, pins rings, locks
Chevy: 4340 Forged steel crank, h-beam rods, name brand forged pistons, pins rings, locks
If you want a cast crank kit, its alot cheaper. If you can afford it, aluminum heads and intake sheds alot of weight off the motors. There isn't a whole great deal of difference of weight between the blocks, actually a Dart Big M is lighter than a IAII block. A stock bbc block is a little heavier than a stock pontiac block, the exact figure escapes me right now.
Its all what you want to do, I was going to put a bbc in my ventura but I decided to build a 3rd gen camaro instead, its all in what you want to do and can afford.
