Old 10-05-2005, 07:01 PM
Jim Heit Jim Heit is offline
Thumbs up Need help with 1964 GTO code numbers
Hello,
I'm looking at purchasing a 64 GTO Hardtop that has been sitting for about 3 years. It is in decent shape with no major body work required and only a small amount of rust on the right rear quarter panel. If purchased, I would consider doing a frame on or perhaps frame off restoration. I need a little help on some of the code on the firewall such as: Body PO16739, ACC 1E-5N-50 and TRIM 214. The car is a 3 carb car with a Hurst Shifter. The paint code is W which indicates that it should be Nocturne Blue but the car has been repainted a rust color or perhaps it was red when repainted. Also, any idea on what kind of price I should be paying considering that the mechanical components are all okay and no engine, transmission work would be required.
Thanks in advance for your help.
Jim in Simi Valley California
Old 10-05-2005, 09:26 PM
3 Deuce 64's Avatar
3 Deuce 64 3 Deuce 64 is offline
Send a message via AIM to 3 Deuce 64
http://gtoalley.com/sixfour.html
Old 10-06-2005, 01:33 PM
Pod Pod is offline
Hi,
Maybe I can help a little. The body number indicates that it was manufactured at the Pontiac plant. The number is purely a sequential number that indicates that it was the 16,739th that was produced at that facility. As a matter of interest, this is the nearest car that I have found to mine to date! My '64 'post is number 16,946. Since they are so close, I can reasonably accurately predict that your car was manufactured in mid May, 1964. The trim code,214, indicates a black interior. The 5N code indicates that it is a GTO. I do not know what the other codes translate to. You would be best to invest $35 into a PHS search which should tell you some more about your car, and confirm that it is what you believe it to be. I cannot advise on values as I live in England. Hopefully somebody over your side of the pond should be able to help you on that. Good luck, and let us know how you get on!
Pod.
Old 10-06-2005, 02:33 PM
Default 64 GTO Code No.s
Thanks. That site was great and I got all the information I needed.
Jim
Old 10-06-2005, 02:44 PM
Thanks for your interest and imput. I was able to find all the information I needed from a GTO site that another member suggested.
Jim
Originally Posted by Pod
Hi,
Pod.
Old 10-06-2005, 02:47 PM
Thanks for that site. It had all the information I needed.
Jim
