Old 10-12-2005, 09:54 PM
[email protected] Bob87@intechnetwork.com is offline
haha. I take it you guys don't approve of my shimming technique.
When I installed the new cam, it appeared to be shifted in the block such that the lifters were not centered on the camshaft lobes. I would have thought that the lifters should ride on the center of the camshaft lobes.
I don't really think this is an adjustable valve train. I don't adjust the valves or anything like a small block chevy. The lifters are hydraulic, but I still torque the rocker nuts on the studs to a give torque spec (20 ft lbs I think).
So you guys agree with me by saying that because the thrust plate is shimmed out, I'm losing some oil pressure out of the front cam bearing? And you also think that the lobes of the camshaft are to be offset from the lifters?
Thanks again for the help.
68 FIREBIRD WITH A 350/TH350 FOR RIGHT NOW. 4 SPD TO COME SOON.
