Old 11-05-2005, 08:38 AM
6T9GTO's Avatar
6T9GTO 6T9GTO is offline
Default Squealing Speedometer
The speedeo in 69 GTO just started acting up today. After hitting 20 mph, it starts squealing and runs up to about 60 mph and bounces all over the place. After I slow down to 20 mph, it settles down again. Can I lube the speedo head somehow, or do I need to replace the unit?
Thanks, Bill
Old 11-05-2005, 09:16 AM
md1twal3 md1twal3 is offline
Thanks, Bill
Bill, it is probably the cable. You can remove the gauge cluster, disconnect the cable from it, pull the cable through the housing and grease it lightly with vasoline...reverse steps. That should do the trick for you.
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi
Old 11-06-2005, 09:55 PM
6T9GTO's Avatar
Thanks md1twal3. I drove the car again today and the speedo did not act up. I will grease the cable some time soon though.
-Bill
Old 11-06-2005, 10:44 PM
-Bill
Cooler weather sometimes brings it out. Glad to offer some info...hopefully it works for you!
Old 11-06-2005, 11:05 PM
Andretti's Avatar
Andretti Andretti is offline
The powder or aerosol graphite works really well and will not thicken up in cooler temp.
Awsome if real time acceleration could be that quick, hu?
Carlos.
