Old 11-08-2005, 02:03 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Originally Posted by rumair
my 97 trans am "only" ran 11.90's, but it went almost 120 mph. that would have been good enough for low 11's with an automatic transmission as opposed to the T-56.
11.67/121 with 1.7 60 ft.
Old 11-08-2005, 02:11 PM
tom s tom s is offline
FYI,if your smart and ARE going to power shift it,get a rev limiter!Tom
Old 11-08-2005, 03:23 PM
rumair rumair is offline
lol...i stand corrected on my car's times. thanks to kiddi for providing the latest (and best) numbers. my times were on nitto drag radials with stock tires up front and i'm pretty sure the new times are on slicks with skinnies up front.
is anybody running a T-56 behind a traditional pontiac engine with any success?
Old 11-08-2005, 03:30 PM
69GTO,is that on the juice or the nuts?Tom
Old 11-08-2005, 03:53 PM
tom- that's on motor...383 LT1, hydraulic roller, ported stock heads, lots of gear and lots of clutch. i used to launch it at 5000 (shifted at 6500) and i think kiddi is leaving even higher than that on the slicks. the car was full weight with a/c, leather, t-tops and full interior when it got on the boat for iceland. i'm not sure if he's taken any weight out or not.
Old 11-09-2005, 09:32 AM
gearbanger's Avatar
gearbanger gearbanger is offline
I have a 6AL box on it, it has saved things a couple of times with the muncie too.!
Old 11-09-2005, 05:13 PM
Junkyard Dog's Avatar
Default Lowest ET
Traditional Pontiac / Tremec combination :
Lowest e.t. = 11.67
Badder than old King Kong
-Jim Croce
Old 11-09-2005, 08:26 PM
firechicken's Avatar
firechicken firechicken is offline
Interesting thread as I'm considering a TKO 600 for my car right now.
I'd pretty well decided to go auto after burning up clutches last season but just can't bring myself to give up the standard.
I think I'll be pushing the 650 tq/hp rating on the Tremec and will hopefully be in the 10s next year.
The WFO Heim joint clutch linkage I saw in HPP looks to be an excellent upgrade to go with the 5-speed.
Anyone using this yet?
Old 11-09-2005, 09:22 PM
rattus rattus is offline
I used heim joints, stock alum rod/tube, and stainless threaded rod to make linkage rods. I just cut the alum to the same length as the stock rods then tapped some threads. I got the joints from McMaster-Carr.
