Old 01-09-2006, 02:12 AM
jamesgennock jamesgennock is offline
Unhappy Valve adjustment question
My brand new engine has been sitting on the stand for a year now with the valves adjusted. I have read that this is not good. SHould I replace the cam and lifters or is it just a slim chance that there will be problems? It seems alittle too late to me to loosen things up? Or am I wrong? Thanks again JamesG
JJG
Old 01-09-2006, 08:43 AM
68lemans462's Avatar
68lemans462 68lemans462 is offline
how big is the cam?
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 01-09-2006, 10:22 AM
OINK 1's Avatar
OINK 1 OINK 1 is offline
Hydraulic or soild? Anti pumps or standard hydraulics?
Oink 1
Greg Merrick
Old 01-09-2006, 10:23 AM
goldeneyee goldeneyee is offline
You really didn't indicate whether hydraulics or solids. Hydraulics would most probably bleed down--no problem. Solids, depending on spring pressure might be an issue. If it were me, I'd try it as it is. You could also pull springs and recheck open and closed spring pressure--this may give you some peace of mind. Good luck..... Bill
Old 01-09-2006, 10:48 AM
Smile
it is just a Ram Air 3 cam with hydralics. Sounds like I can relax now. You guuys are really awesome! Thanks
JJG
