I've noticed this too while checking timing with the plates facing down. Curve will stop at my target 32 deg. than as revs increased timing would slowly increase untill I chickened out. Then I read an article by Rocky R. about this and flipped the center plate and timing curve stopped at desired rpm.
Glad to see some research to back this thou.
best 1/4-11.37 @ 118.03, 96 heads on motor. 11.05 @ 120 on 100shot. |
In what arrangement were the center plates of factory HEI units , numbers up or down ?. Also would the use of the light/weak aftermarket springs allow the weights to reach an over advanced position as the springs that these weights/cam were intended for were heavy rate. Great post
