Old 01-17-2006, 11:15 PM
pontiota pontiota is offline
Default #62 Heads
Are 62's worth anything I bought a 455 with 62's and I don't need the high compression heads would they be worth trying to use and have the pistons dished or should I hold out for some 6x's
Old 01-17-2006, 11:18 PM
takid455 takid455 is offline
Send a message via AIM to takid455
I bought a 455 w/ 62 heads on it. It ran like bat out of hell. I put 96 heads on it and its just not the same. the 62 heads work well on 400's. I would be interested but shipping to NJ would be costly unless you can find a way an economical way to ship them.
1972 HO Trans Am auto White/white
1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue
1978 Trans am gold/ black ,T56, t tops, EFI 474,
Build: http://www.pro-touring.com/showthrea...1978+g+machine
1999 30th Trans Am 6 spd, T top
Old 01-18-2006, 01:21 AM
jotrout jotrout is offline
pontiota
I may have a set of 6X-4 heads that I can trade you for the 62's if your interested, let me know. I also have a set of bare 6X-8's.
Joe
Old 01-18-2006, 03:38 AM
bastereo bastereo is offline
i am interested in the 62 heads if your looking to sell them
Old 01-18-2006, 03:49 AM
form406's Avatar
form406 form406 is offline
as you can see, 62 heads are still popular...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
Old 01-18-2006, 01:01 PM
Beebe's Avatar
Beebe Beebe is offline
# 62's are good heads - 1.77 EX. / 2.11 INT. valves , screw in rocker studs, 72-76 c.c chambers.
* Need Hardend valve seats installed for unleaded gas *
With the 72-76 c.c chambers , they are too small of chambers for a 455 for pump gas . Great performance 400 head , or a 455 with race gas.
Also Known As "Beebe" on other sites....... PZ , Pro-Touring , Lateral-G, TAC
Old 01-18-2006, 02:46 PM
JLMounce JLMounce is offline
I run 62's on my 462.
2 words...raped ape.
-Jason
1969 Pontiac Firebird
Old 01-18-2006, 02:58 PM
P@blo's Avatar
P@blo P@blo is offline
Is a #64 considered a good head as well ?. In Jim Hand's book he mentions how some heads have short turn more towards the center of the valve. How might this impact how these heads flow compared to say a 6X.
Just curious if the #62 and the #64 are similar in the way they might act in stock form.
Old 01-18-2006, 06:55 PM
Pitch 400 Pitch 400 is offline
You can't beat Forward Air if you have a terminal nearby or DHL beats UPS by a long shot. Pitch
Old 01-18-2006, 07:18 PM
marauder's Avatar
marauder marauder is offline
The P-dude is using my 62 heads in my 400/455 rebuild. It will be a 9.5 compression daily driver.
Old 01-18-2006, 09:57 PM
Hitman's Avatar
Hitman Hitman is offline
what all is involved in installing hardend valve seats cause my car runs very strong but pings and I know the heads have not been touched? I have 62's on a 72 400.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 01-19-2006, 11:41 PM
Well I've decide to look for a trade If anyone is interested
I need to lower the compression ratio
I do have a set of 6S heads on my 350 that are 94cc heads maybe I will trade between the two if I can't find someone that whats the 62's
Any offers or comments?
jotrout I pm ed you
Old 01-20-2006, 12:36 AM
I'm interested in trading for your 62's. Where is Sac are you?
Call me
925-833-7866
Old 02-23-2006, 12:30 PM
Sicbird Sicbird is offline
Still have the 62's? I've got a pair of 4x I'd like to trade if you've still got them. They're 98cc off a 400.
Old 02-23-2006, 12:41 PM
Beebe's Avatar
What condition are the 4x in ?
I have a set of 62's that need to be removed from my 455.
Old 02-23-2006, 12:50 PM
James408's Avatar
James408 James408 is offline
I have #62 heads with 72cc on my 408. They are good heads
Old 02-23-2006, 01:41 PM
I found a set of 6x's that I'm going to use so now it looks like I will probably be getting rid of the 62's there just to much for what I need on the 455.
Thanks to everyone for the responses I will probably list them here soon I just need to find a couple of boxes since most everyone hear seems to be on the other coast.
Steve
Old 02-23-2006, 04:32 PM
I’m interested the 62’s, and don't mean to hi-jack the thread, but I’m not sure if they'll work well with my setup. Maybe you guys can help out…
I’ve got a 400 that’s .030” and align honed. The decks need cleaned up, and was going to be zero decked, but I’m not sure if that’s the best option depending on what heads I go with. I haven’t ordered any parts yet, but am planning on going with a 4.25 Ohio crank, 6.8 Scat rods, and custom Ross pistons. I am going for 400-450 hp, depending on how much $ I would have to sink into heads and high octane gas. The motor needs to run on 89-90 pump gas, so I assume 9-9.5:1 static compression. I’m building a solid bottom end so I can switch to KRE’s in a few years if I want to, and I only want to buy pistons once. The motor will be mostly street driven.
Which route is better?
1. Huge dish (about 35cc) with zero deck and ~.04 gasket 9.13:1 comp
2. Less dish (about 30cc) with the piston .015 or so in the hole and ~.04 gasket 9.25:1 comp
3. Even less dish (about 27-28cc), zero deck, .04 gasket, with a 4” stroke 9.22:1 comp
4. Keep the 4x (98cc) heads and thread for studs, put in big valves, light bowl work, deck to optimal compression.
I'm not sure exactly how much work the 4x’s would need otherwise. Probably a standard rebuild. My machinist hasn’t had time to cc or flow bench them for a base point yet. They're out of a '73 2v 400 Lemans. I can't remember the date code, but can call the machine shop and find out.
Old 02-23-2006, 04:55 PM
Teej's Avatar
Teej Teej is offline
James408
You running a thick head gasket? Dished pistons? Any problems with pump gas? I'm just about to swap a set of 62's on to my 400...
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
Old 02-23-2006, 06:15 PM
James408's Avatar
I'm running a standard gasket with TRW forged flat top pistons. I don't remember the part number but with these pistons, I am running 9.98:1 compression. Just easier to say 10.1. I do not have any detonation problems. The car runs good and stays cool. I run 93 octane with a lead additive. I rebuilt this motor about five years ago and it is running great. I had been racing the car for few years before and wanted to freshen up the motor. The TRW's looked great, so I used them again. I have a Mallory Unilite distributor run and have the timing set at 13 degrees initial and 34-35 total all in by 3100 rpm. All in all, I have been running these pistons for 11 years. I like these heads alot.
1969 Firebird "400". 408 Pontiac, #62 heads, 274 XE cam, Eddy RPM intake, Quick Fuel Slayer 750, Carter Super Street fuel pump, Mallory Unilite, Turbo 400 with shift kit, Continental "Jim Hand Special" 3200 stall, 12 bolt 4.10 posi. 1 5/8 inch headers, 2.5 exhaust with Dynomax Ultraflos.
