| The Body Shop TECH General questions that don't fit in any other forum |
more pics as can be seen the 64 and 65 rear bumper brackets are not even close also compare the two shields you will see that they are different as well the 64 has a rib down the center and has a twist the 65 is raised in the center now the 64 may fit but if you look at the 65 it is notched on both sides because the 65 bracked has an angle around the edge wher the 64 is flat so if you notch the passenger side on both sides as the 65 is tou more than likely be able to install it Don
