I have a 70 gto will 16x8 from wheel vintiques rub the front when turning the wheels? or should i be safe and go with the 7s?
The wheels themselves won't rub. The only rubbing you have to worry about is the tire. Depending on width or sidewall height you may rub. But you would have the same problem regardless of 7 or 8" wheels.
If you are happy with the look of your current tires and just want to upgrade to a larger wheel try the following link. You can enter your current size and then plug in 16" sizes to match your overall diameter, tread width ... http://www.1010tires.com/TireSizeCalculator.asp
WORK HARDER. Millions on welfare depend on you. |
Probably depends on the backspacing and tire selection.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
If i wanna put wheel vintiques 15x7" all around on my 68 firebird couple, will those rub
i guess my question should be with 16x8s what tire can i put in there?
Can't reiterate the importance of figuring or stating backspacing too much. I have a set of 16x8s from a 4th gen Firebird--6-3/8" backspacing. They will obviously not clear without spacers. You'll need no less than 5" BS to center the wheel, after that you can get a 245/50-16 on them.
I had a set of 16 x 8 wheels with 245/50/16 on my 64 and 66 Tempest. they had 4 3/4" backspacing. Still have em for sale if anyone is interested. American racing wheels. There were originally on my 87 Firebird I had.
