Old 03-15-2006, 12:16 PM
Toy4Chris Toy4Chris is offline
Default SPARK PLUG GAP
I recently purchased a new set of plugs for my car. Suspected that the previous set (only 3months old) was bad, as the car ran very poorly. I had asked at the retail store (Auto Zone) the proper gap, which they said was .044. After installing the new plugs, and seeing that the car ran much better, I noticed under the hood that the gap was to be set at .054
My question is what needs to be done here? Should I take them out again and re-adjust the gaps from .044 to .054 or leave them alone? What would be downfall of having a gap approx 20% smaller than what the manufacturer suggests.
THANKS FOR THE HELP
Save it.....you never know!
1967 Firebird 455 Th400
Old 03-15-2006, 12:56 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
What ignition do you have? Original points? HEI? MSD?
Old 03-15-2006, 02:50 PM
Default plug gap
This problem I'm having is with a 93 Ford Econoline E150 v8 van. Sorry for not giving those details. HEI
Old 03-15-2006, 06:35 PM
Billy177's Avatar
Billy177 Billy177 is offline
if they are easy i would regap them if not then i would just leave them. it will not do any harm leaving them at .45
Old 03-15-2006, 07:20 PM
Default gap
6 plugs are pretty easy...the other 2 are HARD!!!!
Will it run any smoother with the correct gap? What will a smaller gap do different than if it were set correctly???
Old 03-16-2006, 07:11 PM
Billy177's Avatar
maby a tiny bit worse gas milage but that is all
Old 03-30-2006, 01:09 PM
Just for my own knowledge...what will happen if the gap is larger than spec?
Smaller than spec?
Besides what what already mentioned.....perhaps slightly less fuel economy, will the motor run the same whether larger gap, normal gap, or smaller gap?
Just curious.
With the price of gas headed to $3 soon, I can use any fuel savings where possible.
WHY IS GAS HEADING TO $3 AGAIN??? I just love Mr. Bush...don't you???
Old 03-30-2006, 03:02 PM
Large gaps will suppress the spark-ignition effect at peak torque. Only benefit is prolonged electrode life. I think the MFGrs made a big mistake on .080" gaps
So, for best Mileage, power, go for the small gaps like .040 to .045.
Only drawback is quickened EDM"d electrode wear.
.020-gaps too small, probably show poor flamefront repeatability. 035 gaps maybe the threshold into success.
Old 03-31-2006, 06:34 AM
Geoff Geoff is offline
If it runs better with a larger gap, leave them there. The ignition system [ leads, insulation ] etc is obviously in good condition because the bigger gap needs a higher arcing voltage to fire the gap. If the system was in poor condition, you would get misfires etc. Instead, you found the car ran better.
The only downside is that the gaps will need to be checked & reset more often. You don't want the gaps to erode too much, to the point you get misfires.
0.054" is not that large for a medium compression, normally aspirated engine. GM recommended 0.060" gaps for the HEI when it was introduced.
