Old 04-13-2006, 10:48 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
Default electric fuel pump...how loud?? (UPDATE)
just installed a summit electric fuel pump (140 gph 30 psi max) anyways, just how loud are those things supposed to be. im getting plenty of fuel to the carb but it sounds like a freaking house vacuum cleaner. is this normal?
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 04-13-2006, 10:59 PM
Tripower455's Avatar
My "quiet" Mallory 140 is pretty loud. The problem is that I have the pump mounted to the front of the trunk pan, and it is like a huge resonator.........
Old 04-13-2006, 11:03 PM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
oh man
im bout to install mine, should i cover it with sound deadener?
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 04-13-2006, 11:04 PM
BILTIT's Avatar
BILTIT BILTIT is offline
http://store.summitracing.com/partde...5&autoview=sku
I am going to be installing these, not sure how well they will work but must be an improvement!
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 04-13-2006, 11:05 PM
wheelspin's Avatar
Arrow
Get used to it, or upgrade to 3" exhaust . Seriously, even when rubber mounted, ALL vane-type pumps are loud.
Les Iden
Old 04-13-2006, 11:48 PM
6D6GOAT's Avatar
yep, thats where i have mine mounted (i ll post a picture tomorrow) i fabbed up a bracket that hangs from the front of the floor pan right in front of the gas tank. i even insulated it with rubber gromets.
i wonder what would happen if you hung it from a radiator hose. stick the top of the pump in the hose, clamp it with a hose clamp and attach the top half to a bracket from the front of the trunk pan.. so it will hang and dangle freely...........kind of like a...........well, never mind
hhhhmmmmmm. i might give that a try because i think its the resonance that is bad, not so much the pump
My T56 Install
My Turbo Build
Misc Build Pics
Old 04-14-2006, 12:23 AM
I used the same ones between the pump and mounting plate. They helped a little.
I have mine in the same place as Vic. I am going to try some grommets between the plate and the trunk next, but I am putting in a sumped tank, and will try to relocate the pump to the frame rails, which should be a lot quieter due to less resonance.....
BTW, it's not that annoying. The guys in my car club give me a hard time about it, but it really doesn't bother me that much, especially since I don't have any fuel delivery issues at all........
Old 04-14-2006, 02:22 AM
RobbMc's Avatar
RobbMc RobbMc is offline
These are quiet:
http://www.robbmcperformance.com/pro...ontiac110.html
http://www.robbmcperformance.com/pro...ontiac220.html
Old 04-14-2006, 07:10 AM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
they are all loud, the bigger & badder the louder. I agree but go 3.5 inch exhaust, & you wont hear it much, & free up some flow at the same time
Old 04-14-2006, 09:01 AM
GS470 GS470 is offline
Maybe I'm just going deaf (OK, the years of loud rock and roll have probably caught up with me) and the 3" Pypes exhaust may have something to do with it, but I don't think my Mallory 140 is that loud (I don't know how it compares to the Summit pump). I've got 2 rubber pads to isolate the pump. One located between the mounting bracket and the trunk pan and another one between the pump and the mounting bracket. I seriously don't hear the pump running when I'm just cruising along with the car running at low RPMs, so I have no complaints.
It's hard to see, but here's a pic of how it's mounted: http://home.comcast.net/~gs470/LeManz283.jpg
'72 LeMans 2Dr Hardtop
My first car, purchased in 1980
468 Stroker / KRE 315 / HR cam by SD Performance, Tremec TKO II 5spd
'96 Corvette Grand Sport (#470 of 1000 built)
Mildly modded LT4, 6spd
'07 Corvette Z06
Mildly modded LS7, 6spd
'67 Chevelle Convertible
LS6 (405HP Z06), 700R4
Old 04-14-2006, 09:04 AM
steve's Avatar
steve steve is offline
mine sounds like i've got a wood chipper in my trunk. when i put in new carpet and carpet pads it helped a lot.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 04-14-2006, 05:26 PM
big head big head is offline
Default fuel pump
I have a barry grant 220 street pump . there all noisy compared to mechanical pump...
Old 04-14-2006, 09:28 PM
carcrazy carcrazy is offline
Just put in a Holley Red in my son's El Camino. Damn thing can wake the dead!
Old 04-14-2006, 10:02 PM
Brandi Kay's Avatar
oh man....
good thing im deaf
lol
:range r:
Old 04-14-2006, 10:23 PM
Joel Koontz Joel Koontz is offline
Running a return style regulator/return line is supposed to quiet them quite a lot. It is also said to make them run cooler, draw less current and last much longer.
Old 04-14-2006, 10:53 PM
RobbMc's Avatar
All true. Return regulators are really a plus in many ways when running an electric pump.
Gerotor style pumps (Mallory and some of the newer Holley designs) are quieter than the rotory vane style pumps (which includes most others). The rotory vane pumps with metal vanes or rollers (most use metal, including the classic Holley pumps) are noisier than those with non-metalic vanes like the new Jegs brand pumps and the Edelbrock pumps.
No matter which kind of pump you use, you can make it quieter with rubber mounts.
Old 04-14-2006, 11:14 PM
Emphasis on supposed to..... If the return style regulator quiets the M140, I'd hate to hear it without the return reg!
Mine has 1/2" feed and return lines (including the pickup/return in the sending unit and it still sounds like a wood chipper (thanks Steve ).....
Old 04-15-2006, 10:43 AM
KS circutguy's Avatar
The quietest pump available now ($450.00) is this new Barry Grant unit.
The new Holley is much quieter than 'old Blue'.
http://barrygrant.com/bgfuel/default.aspx?page=44
Old 04-24-2006, 09:32 PM
6D6GOAT's Avatar
i just started a new
thread...http://216.178.81.108/forums/showthr...59#post2509759
My T56 Install
My Turbo Build
Misc Build Pics
