Old 07-16-2006, 06:39 AM
Darren.D's Avatar
Darren.D Darren.D is offline
Default My Hooker just don't fit!
Hello there people. I have a slight problem with one, headers fit. Here goes, i have a frame for my 70 lemans from the south west (no rust), i'ts out of the car. I've set it up with my motor, tranny, e-heads and the headers. I thought i would save a lot of time doing this now. Ok, first i'm running a 455 -400 turbo combo e-heads and the hooker super comps. I've also changed the motor mounts to the newer clam? frame mounts.I have taken a lot of time to set everything straight and level, even getting the right amount of degree, tilt towards the rear diff. The passanger side fits like a dream but the drivers side is way to snug. The header can not be fully bolted up, if i do the header hits the frame. Has anybody run into this same problem? I don't think it's the mounts, there is just to much gap. I'm wondering if the thing is bent. there brand new, but the box has seen better days. Anyone else have this problem? got a fix, let me know thanks everyone. Darren
Old 07-16-2006, 12:04 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Heat the header pipes and bend it?
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 07-18-2006, 02:12 PM
sts sts is offline
Typical hooker header. Everyone else's are garbage too, so we're all sol.
Old 07-18-2006, 08:42 PM
grnt37 grnt37 is offline
I have hooker's on my T-37,one side fits good the other side leaks.Im looking for better headers.
Old 07-19-2006, 12:06 AM
Brandi Kay's Avatar
Brandi Kay Brandi Kay is offline
they put hooker headers on mine, they dont leak.
Keepin it real in 2025.
'just another time traveler...
:range r:
Old 07-19-2006, 01:27 AM
getmygoat's Avatar
Default Ram air manifolds
I'd suggest ram air manifolds instead.... unless you are building an all out race car, why deal with the leak and ground clearance headaches?
But then again, I'm the guy who wanted a 4-speed w A/C car.
Old 07-22-2006, 08:58 AM
Red Box Rebel Red Box Rebel is offline
1. Hey, I have a 4 Spd GTO with factory A/C. I have the need to be cool far more frequently than I have the need for speed.
