Old 07-17-2006, 01:50 PM
Steve Barcak's Avatar
chiphead- get your facts straight, you don't know what you are talking about, ignore his last post. It is full of wrongs.
Steve Barcak www.pontiacheaven.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 07-17-2006, 06:32 PM
chiphead's Avatar
chiphead chiphead is offline
How about enlighting us? I'd like to learn as well. This site doesnt often touch on engines made before '66. '59 was the first year for 389, right? I thought the crank snout was shorter, the intake manifold bolt pattern was different, the heads had smaller valves and closed chambers, the front assemblies not interchangable with '67-newer engines, etc. Some early engines depending on year and size had the 'rubber rods', different starter mounting, etc. What interchanges between the early engines and the '65-later engines?
If I see a technical error made by a previous poster, I politely point it out. Why are you the asshole?
Old 07-17-2006, 07:00 PM
tom s tom s is offline
any pontiac head-timing-cover-intake will fit a 59 block if they match,that is a 61-64 head with a 61-64 intake or a 65up head and intake.The bellhousing and flywheel are issues which can be overcome with adapters but usually not worth the trouble.All the internals will interchange like oil pump,cam lifters etc.Tom
Old 07-17-2006, 07:15 PM
chiphead's Avatar
Ah OK. So what's the diff between '59-60 top ends and '61-64? Did the early 389s use the same bore, stroke and journal sizes as the 65-later 389s? Was the crank snout shorter '64-earlier? Did the earlier engines use windage trays, baffled oil pans, etc? Oil pump driveshaft the same? And what about the motor mounts?
Old 07-17-2006, 09:03 PM
crank snouts are shorter but that is NBD.I have 2 engines with short snout cranks and 69-70 timing covers and balancers.Dont remember about the baffels.Valley covers are diff for diff years but are interchangeable depending on the intake.The motor mounts im really not sure about as I have never used a pre 61 block.The bore and stroke on a 59 389 is the same as a 66.One important thing is to use the correct timing cover with the correct balancer and pulleys as there are changes thru the years.Tom
Old 07-17-2006, 09:38 PM
You're posting false info and I am the a hole? It is probably best you remain ignorant. You got some info here but, hardly all of it.
I don't hide behind a nick name. Those who do, as you havem tend to speak out with false info and then call others expletives.
Real class you are
Hosting-
Phil 2:11
Old 07-17-2006, 10:27 PM
WOW Steve!Someone piss in you cornflakes?He along with most of this and other pontiac boards dont know ANYTHING about pre 65 stuff.Give him a little knowledge instead of jumping on him!Tom
