I am thinking about running in a 10 index class at our local track.
I would like to do it without the bottle in a 2800 to 3000# car. Who is running at or near 10 flat and what is your combo?
"resurfacing Pa highways 2 long black strips at a time" 78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z Best to date [email protected] mph at 3250# 79 Grand Prix, will be new home for the 440 Goal 9.75z@135mph at 2900# 83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z Making it the Ultimate Utility Vehicle Go, tow and show (not so much show, yet) |
In a good chassis at 2800lbs, my 625hp 505 combo and a hyd roller will run that number.
Check all the classes you might want to run. Some require stock Dash, windshield, frame rails, True 10.5 tire ECT.
I back halfed my car and can't run some classes that i would like to. My car ended up @ 3440 race wieght and has a 642 hp 462 and runs 10.60-70's in the Desert air. (Desert air) 3000' elevation but acts like 6000'. It should run a 10 flat or better with excellent track conditions. A 600 - 650 hp engine combo shouldn't be hard to come up with. Lots of ways to get there. You can get more info on my combo search (titles)(Race section )( What a rush) JK
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 Last edited by JKrull66; 07-24-2006 at 02:14 PM. |
Shouldn't be too hard to do. Light car, and above mentioned HP figures should get ya there. Your just gonna have to hope the car works...IE suspension, etc.
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
Slide rule says you will need around 600hp to run a 10.0 with a 3000lb car.
Systems under stress fail catastrophically |
My spare motor I have for sale went 10.03 and 10.04 at 3450#.
Really more motor than I need. I am looking for 11.50 to 12.25 at 3500# |
Here's mine.Ran 10.17 @ 132 weighing 3275lbs. 455 w/non-wideport ported E-heads and 1.6 shaft rockers. Eagle crank, standard length Eagle rods w/ Ross flat tops. Solid roller 271/278 on 106 ls, 660 lift. Victor intake w/1150 Dominator. 1.76 Powerglide, 12bolt w/4.33 gears and 30" tall slicks.
I think Shotgun already has some good parts to work with!
![]() You'll just need to select gear/cam/converter, and you should be there.
What parts ya got ???
My niegbor has a 10.00 Cat.... Just add Corncob and Turpintine....LOL
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 |
ran 10.00 9.90 in 3000 lb 68 bird 10 years ago 455 ram air 4 heads hyd flat tappet cam 12 to 1 comp .8 inc conv 14 x32 tires 4.10 gear
pure pontiacpowerd 86 grand am 455 eheads solid flat tappet cam 8;95 @152 HOFFMAN RACING |
440 short block for starters:455 filled to bottom of the freeze plugs,Moldex billet crank,Oliver Aluminum rods,4 bolt splayed caps,Non wide port E-heads flow approx 320 with 2.18/1.77 valves,Victor intake,worked 950 holley,th400 with trans brake,12 bolt with spool.
Cam,convertor,rear gear and tire to be determined. I really interested in how "other" people got there so I can see if I am on the right track and maybe learn from your failures and success'.
63 lemans Back Half, all steel and glass, 3440 lbs race ready, 462: peak tq 601 @ 5000, peak hp 642 @ 6250, Howard Aluminum Rods, victor, 1050, similar heads, Ross flat tops, t400 w / brake, 9" ATI treemaster MRT stalls @ 4800. ford 9" 4.56 gears, 14-32 MT slicks, 3.5 Exhaust, x pipe, bullets, Mallory 250 pump
Comp .630 lift 274 280 @.050. 1.44 60' 10.60s @ 3000' w/ density @ 5880' 92 degrees. goes through the traps @ 6050 @ 126 put all of that in desktop Drag2000 and change the conditions .... to excellent 9.79 @ 138 6682 RPM. JK
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 Last edited by JKrull66; 07-25-2006 at 04:02 PM. |
Thanks JK,I like your second answer better!
The things I spent money on twice, Tires, reargears, tq converter, and fuel pump.
The tires and the gears might have been avoided, but buy a good Tq the first time. The ones that will work on a 600 hp (Brand X engine) my motor powered right through. and get a size bigger fuel pump than you think you need. good luck JK
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 Last edited by JKrull66; 07-25-2006 at 04:01 PM. |
I also have the converter out of that combo for sale also. |
That's my goal also for the one at the machine shop now, so I'm interested in this thread also. 3400-3500lb second Gen F body. Hoping to do it with just Caltracs and a stock type rear suspension. 500" (4.350/4.21), non wide port E heads, Victor, 850.Roller cam to still be selected.Looking at a 264/268 @ 0.050.
My fathers combination goes like this...
10.09/132mph with best 1.5 60ft. on asphalt track, leaving at idle. It's a 65 Tempest (#3200 with driver) with 428 (.40 over), 72cc E-heads ported by owner, factory cast crank with 2 bolt mains. Eagle rods, Ross pistons, 12 flat compression, Victor intake with 1150 carb. mechanical roller at .700 lift (1.65 arms) and duration around .265 at .050..... 12 bolt rear with 4.33 gear, Ati 4500-4800 stall, 8". Powerglide built by owner.. motor is also built by owner. 30x10.5 tires and "stock" Dick miller suspension components. Last edited by RUDOLFSSON; 07-27-2006 at 09:14 PM. |
Thanks for the info.
I am thinking 270/280 with 400 lobe lift mech roller,looks similar to what is listed so far.
