Old 07-27-2006, 12:06 PM
2QUICK4U's Avatar
2QUICK4U 2QUICK4U is offline
Originally Posted by UKcat
I have the original wiring, I think. There is a wire that goes down to the tranny and is hooked to it. There are two wire connectors on the harness, in behind the carb. that are not hooked to anything. One is black, as is the wire on the tranny, the other is black with a yellow stripe. Would these be the correct terminals or are they for something else I don't have??
Yes, those wires should be hooked up to your trans kickdown switch: one hot wire and the other to the trans. All the switch does is close a contact when you put the pedal to the floor and tells the trans to down shift
If you're not liven life in the fast lane, get the hell out of my way
1995 Trans Am LT1 **SOLD**
1967 Firebird 326 ci: headmenn headers, rpm manifold, holley 670cfm street avenger, HEI
