Old 07-29-2006, 01:54 PM
Originally Posted by grnt37
Hey guys thanks for the replies,here's a better explanation of what my plans are"when I save enough money".I have an old pb4 edelbrock w/ a 600 holley on the car right now.Im not crazy about quadrajets,although I know they can be a great carb if bulit right.My friend has a '70 GTO SS/IA car w/a 400 and a quadrajet runs low 10's.I had a '69 cast intake before w/ a quadrajet car just didn't run good.Although that could of been my fault?Future plans are aluminum heads and a better cam,thats why I was thinking the rpm intake.Would the car run like crap w/ the rpm intake until I change everything?I do know it would run better w/ the performer intake,but when time comes I'll need a better intake with the new heads and cam.As I mentioned for now it has the 066 cam 273/282 .410/.414 lift.Again thanks for the info!:
If you're planning to upgrade in the future buying the RPM intake now would be a wise move. It will run surprisingly well on your near-stock 400.
Definitely get hooked up with one of Cliff's Q-jets, best carb for the money in terms of both performance and fuel efficiency.
I'm sure a Holley that's properly tuned will give you the same power, but on the more street-oriented combos (no big solid-roller cams that won't pull decent mileage no matter what carb is there) the Q-jet will offer better gas mileage.
Anyone who says gas mileage doesn't matter is full of it, the higher price of fuel nowadays will limit the amount of use these cars will get for most people. A car that can get, for example 10 MPG instead of 8 MPG, will equal a lot more fun per dollar and that definitely matters for most of us.
My street 406 with E-heads, RPM intake, Crower 60916 flat-tappet hydraulic cam (221/229,.500"/.517" w/1.65s) and one of Cliff's 800 Q-jets:
ID:	60329   Click image for larger version
ID:	60330   Click image for larger version
