Old 08-07-2006, 07:01 PM
P@blo's Avatar
P@blo P@blo is online now
Pitch, I was under the impression all the Rhoads came with the good internal snap ring and have never heard of them coming with the wire clips. To check you could pop off a clip and look on the inner plunger for the Rhoads groove/flat to be sure.
If they are the Rhoads then I would measure the grove and the housing diameters to get an idea of what snap ring size you need. Mine were the single groove below the oil band sealed Power lifters bought before 2002 but had the cheap retainers as well.
I had a PY member help with all of this and a bunch of other top end issues so this is sort of Geoff's info but wanted to post it for others wanting to replace the wire retainers.
Thanks again Geoff
Old 08-11-2006, 09:48 AM
P@blo's Avatar
About the iron chilled bottom lifters, Do these have to be matched with a cam that is hardened/hard faced as well ? Here is a blurb from Isky's web site.
"Isky Chilled Iron Solid lifters are compatible with our hard face overlay series cams only (not for cast billet type cams). Hardened by the chill-plate method which produces ideal surface grain structure, they are the only flat tappets that will survive in the grueling environment of today's funny car, fuel-dragster and competition engines."
Is that why everyone is running a standard Johnson hydraulic lifter and can find nothing regarding this on the forums other than what was posted by Hard Timess. Any ideas ?
