Old 08-06-2006, 11:30 PM
69firebird4004spd's Avatar
69firebird4004spd 69firebird4004spd is offline
Default 78/79 t/a engine paint
Need help trying to locate correct engine color paint for 78 and 79 6.6 T/A engines standard corporate blue is not correct .Corporate color would be correct for 403 engines and chevy 305, 350 engines thanks
Old 08-07-2006, 08:57 AM
69*Goat's Avatar
69*Goat 69*Goat is offline
Corporate Blue was the stock color for my 77' 400. Why would 78 be any different?
461 Cu. In. Pure Pontiac Power:
1969 Pontiac GTO - Back On Top - Popular Hot Rodding Magazine
Old 08-07-2006, 09:51 AM
Corporate Blue is as close as you can get to out of the can. My 78 was slightly more green, still got the valve covers to compare. Not as green as soem of the 73 SDs were.
Old 08-07-2006, 03:37 PM
I knew I wasnt going crazy,,, anyone know where I can get it???
Old 08-07-2006, 03:53 PM
69*Goat's Avatar
Have you tried Eastwoods?
Old 08-07-2006, 08:20 PM
Warren Seale Warren Seale is offline
I've seen corporate blue from Dupli Color in the local parts stores and Walmart.
Warren
Old 08-08-2006, 01:42 AM
MalteseFalcon's Avatar
MalteseFalcon MalteseFalcon is offline
John Witzke has previously posted this formula for the 1977-78 W72 Engine color. It isn't available anywhere off the shelf. You have to get a paint shop to mix it up and put it in a rattle can for you. I understand that this was color matched from an unexposed bit of paint off an original W72 engine.
Tinting Guide Mix size: Special (6.25 % of gallon) 8.0 oz
2K-553 Brilliant Blue 61.2
2K-010 White 179.7
2K-024 Ochre 240.2
2K-550 Violet 246.3
2K-011 Black 258.9
NON-CUM Guide
2K-010 White 118.5
2K-024 Ochre 60.5
2K-550 Violet 6.1
2K-011 Black 12.6
Steve
1978 WS6 W72 4 Speed Trans Am - Martinique Blue on Light Blue - Fire Am Restification Project
1972 4-Speed 455 HO Trans Am - Original Cameo White on Blue car - Restoration Project
Old 08-08-2006, 02:09 PM
Thank you.. this will help out alot
Old 08-11-2006, 10:56 AM
Mr W72's Avatar
Mr W72 Mr W72 is offline
I would like to clarify, 1977-79 L78 and W72 engine appears to be the same color use by the other GM divisions. I am sure it is GM Blue originally used back then, however, I have stated in the past and stand by what I have stated, the GM blue paint found in many of the aftermarket paint companies spray cans is too blue for correct factory appearance.
John Witzke
POCI Tech Advisor
1977-79 W72 Performance Package Historian
Old 12-24-2006, 04:56 PM
berrygoat's Avatar
berrygoat berrygoat is offline
I thought 77 used Strato Blue and 78 and later Corporate blue ? I hope that's the case as I painted the engine in my 77 (built late 76) Strato Blue.
Old 12-24-2006, 05:10 PM
Mr W72's Avatar
Very early 1977 cars engines were the same shade of blue used during 1976 model year, then a change to the blue used for the remainder of 1977 and on.
John Witzke
POCI Tech Advisor
Old 12-24-2006, 05:30 PM
Mr W72's Avatar
Here is my 1977 W72 with 11,300 original miles from new.
Name:	our engine 102206 tape.JPG
John Witzke
POCI Tech Advisor
Old 12-24-2006, 05:35 PM
Mr W72's Avatar
Here is a picture of a ultra low mile 1976 455. This shade of blue was used on early 1977 engines. I am not sure of the switch over date to the shade of blue found on mine (see above) occured.
Name:	76 455 04.jpg
John Witzke
POCI Tech Advisor
Old 12-24-2006, 06:00 PM
Mr W72's Avatar
Here is another of my engine compartment. My engine retains approx 90 percent of the original paint.
Name:	our engine detail 102206 03.JPG
John Witzke
POCI Tech Advisor
Old 01-09-2007, 02:54 AM
schwartz677's Avatar
schwartz677 schwartz677 is offline
you can get a near exact color match through summitracing.com look under VHT pontiac blue, the item # is sp122, there isn't a picture, but it is correct for 75-79 pontiac 400
Old 01-09-2007, 04:40 AM
2manyT/A'S's Avatar
Here's an interesting chart.
http://fiedlerh.home.att.net/enginecolor.htm
Unfortunately ALL of the 77-81 Corporate Blue chioces are close but no cigar!
Now you can pick your favorite "incorrect" color.
You'd think that one of these companys would take the time to "get it RIGHT!"
