Old 08-13-2006, 10:12 AM
sixxty7's Avatar
sixxty7 sixxty7 is offline
Wink
no, two wires attached to the large post. purprle wire to the S terminal. i will look at it again. but i swear nothing was touching .everything was grounded correctly. distributor to negative on coil. purprle to S on solenoid. never seen the starter engage like it did when i hooked up the battery. like i said i will look at it again. but from what seen evrything looked good. if need be i will take ths starter offf to be checked. this starter worked fine before. why with the key engaged to the start position. i dont hear the starter do anything? starter is not mounted, but sitting on a jack stand. now what?
