Old 08-15-2006, 01:06 PM
77TA406 77TA406 is offline
Default 4.210 vs 4.250
I am going to purchase a Ohio Crankshaft for a future stroker 400 build. I have a few questions that I hope someone can answer. First of all, let me say that the few cubic inches that I would gain by using a 4.250 crank are really not that important to me, but I still would consider using that crank instead of a 4.210. Here is my dilemma.
The 4.250 and 4.210 x 3" cranks cost about the same...$295.00
BBC forged rods are a little cheaper than Pontiac rods, so that makes the 4.250 crank more attractive...
Question:
Is there a good selection of pistons available from various manufacturers, or are they still considered a "custom" piston available from Ross or JE? Does TRW make pistons for this set up? Basically, I can save a few bucks on forged rods by going to the 4.250 crank, but if I have to spend hundreds of dollars more to get a custom piston, the few extra CI aren't worth it for me.
Thanks for any advice..
Chris
Old 08-15-2006, 01:22 PM
Ron H's Avatar
Ron H Ron H is offline
www.pontiacdude.cc www.krepower.com
68 Firebird
Are you running with the wind or breaking it?
Old 08-15-2006, 04:41 PM
Steve C. Steve C. is offline
SRP makes a special piston for the 4.250 stroke crank that comes in the kit supplied by Eagle. I think its 459 grams. It has .990 pins and made for a 4.185 bore. The compression height is 1.285. P/n 196830 (Mfg. job # 298758).
You might call them and see if they will sell a set.
Old 08-15-2006, 04:50 PM
Desert Dwella Desert Dwella is offline
Wink Call Spotts ask for Paul
www.spottsperformance.com,
I bought the stroker kit from them. It came with the Ohio crank and eagle rods, ross pistons. You CANNOT go cheap! If you are gonna stroke the 400 getting the right stuff is peace of mind.
Worth more than what you are gonna spend.
You get what you pay for man, sometimes going cheap will cost you in the long run.
Old 08-15-2006, 04:59 PM
Thanks for the info guys. I wasn't trying to cheap out...just trying to see if the extra cubic inches was worth the added expense for custom pistons. If I stay with the 4.210 crank, I can use Pontiac 6.625 rods and pistons that are available from nearly anyone...
Chris
Old 08-15-2006, 06:20 PM
Does anyone know the weight of a TRW forged 455...4.150 piston and a KB hypereutectic 455...4.150 piston. Thanks
Old 08-15-2006, 06:41 PM
Post
I think the OHIO cranks and the kits are set up for CHEVY rods thus letting you use CHEVY pistons. Since Chevy is so common you already save $$ there. The Eagle rods that I have are BB Chevy and the Pistons are for the Chevy rods. Although they are in a 400 Pontiac Chevy parts are what I have.
Old 08-15-2006, 07:26 PM
TRW forged 0.030 455 is around 600-610 gms, forgot exactly my last set. TRW has specs in the book.
Other factors to consider.
Reduced piston weight with the longer rod combo. (?)
Reduced bearing speed with the smaller journals.
Increased rod ratio and less side loading with the longer rod combo.
Old 08-16-2006, 01:47 PM
birdzz birdzz is offline
Do the chevy pistons have the correct valve reliefs, though?
Old 08-16-2006, 02:59 PM
crazypont crazypont is offline
Default Enginecraft has the rod for you
I have not annouced the release of these rods yet but we now offer a 6.605" rod that will allow you to use a 4.250/2.200 crank with an off the shelf pontiac floater piston such as KB or Sealed power.
These are H-beam, ARP 8740 bolts, 810 grams, bushed small end. Small end is .980 for pontiac piston and large end is BBC rod journal size.
We also offer the 4.250/2.200/3"main crank -but with 2350g bobweight and straight shot oiling. The cranks we sell all have straight shot oiling. This is the same way the factory drilled the 389/400 cranks.
www.enginecraft.com
We also now have 4340 I beam capbolt rods in stock- stock pontiac dimensions-press pin-777g
More to be announced in another thread soon
-Dave
Old 08-16-2006, 03:03 PM
Now you tell me! I could have used them and an availble billet crank with my pistons.
Old 08-16-2006, 03:19 PM
Sorry Skip I just got them in last week!
Old 08-16-2006, 04:53 PM
Region Warrior's Avatar
Being a Ponti-atic, you would think i would say Pontiac rods.
But over the years, ive found the Chevy rod/piston deal alitte better for availability and price.
I also like long stroke engines for the street. More low end torque without high rev's. More street friendly gears too.
Old 08-16-2006, 05:00 PM
Crazypont, what is the bob wieght of your 6.605/4.250/2.200?
I guess it's a matter of crank vs rod/piston stroke.
Everyone has thier favorite.
Old 08-16-2006, 06:48 PM
Well my shirtblock was already assembled then.. I'll keep that in mind though!
Old 08-17-2006, 09:41 AM
PONTIAC DUDE's Avatar
Post FWIW:
U can use a Eagle 6.635 rod (BBC sizes) with a 455 crank and lightweight custom pistons we sell at $550.00
Old 08-17-2006, 10:17 PM
goquick's Avatar
goquick goquick is offline
The longer rod will help the engine live longer because of less wear. But to really up the power, the debate hasn't really been settled for short or long rod. On a street car, use the longest rod you can get a piston for.
Old 08-17-2006, 10:21 PM
goquick's Avatar
Crazypont; Isn't that the bbf lenght for their strokers and stock reground cranks with bbc journals?
Old 08-18-2006, 12:10 AM
goquick-
To answer you question I am not sure what the length of the Big Ford rod is. I simply wanted to offer a rod that is minus .020" length of the stock Pontiac to give another option for a budget stroker assembly. I will have these 6.605" Length rods in the 4340 press fit rod soon also for a lighter and cheaper rod in case you want to run an off-the-shelf cast 455 piston or the press fit TRW piston with the 4.250 stroke crank. The more options for people the better! As far as the cranks we offer, these are brand new castings. We also have the new 4" stroke 3 inch main cranks, too. Check out www.enginecraft.com for crank info.
ponchoshop-
Our 4.250" stroker crank with 2.200" rod journals has a 2350g bob weight.
4" stroker cranks have a BW of 2400g
