Old 07-17-2006, 02:49 PM
smdellin's Avatar
smdellin smdellin is offline
Default Pontiac Bonneville - Weird Start Issue
My boss has an issue he sent to me and thought maybe you guys might be able to help. My first impression is the crank sensor or possibly the resistor type key may be wore out (can that happen?).
My car has an intermittent starting problem. When the ignition is turned from “off” through “on” to “start” the car is dead, the starter does not crank, nothing happens. (I can sit at “on” prior to “start” and the radio works, the A/C fan works, all power windows and sunroof work) When the key is immediately cycled to “off” then back to “start” the car will start with no hesitation. The battery is new; the power cables to the starter are new.
Car specifics: 1999 Pontiac Bonneville, 3.8L V6 engine, 95k miles.
I bet if you were in some old west gang, and you were dragging a guy along the ground with your horse, It'd probably make you really mad to look back and see him reading a magazine.
Old 07-26-2006, 06:15 AM
SIPLOWGUY SIPLOWGUY is offline
Could be a bad ignition switch.
Old 08-28-2006, 07:12 PM
WW3's Avatar
WW3 WW3 is offline
Is the "security" light going off on the first rotation of the key? If not your VATS ignition key needs replaced. Or the VATS module is bad.
former home of the 4-speed Can am
Old 08-31-2006, 11:02 PM
BR57's Avatar
BR57 BR57 is offline
I have a 92 and it started doing a similar thing. Security light would stay lit. Only way to start car was to disconnect battery, reconnect and start. I got the extra key supplied when I purchased the car new and it has never done it again.
Old 09-07-2006, 07:07 PM
BR57's Avatar
What happened? Did he try the new key?
Old 09-11-2006, 09:50 AM
smdellin's Avatar
Tried the new key and experienced the same problem. He finally took it in and had the VATS disabled.
Old 09-11-2006, 09:53 AM
BR57's Avatar
Thumbs up
Ok, thanks, that's good information to know.
Old 09-11-2006, 11:47 PM
bastard's Avatar
bastard bastard is offline
Default Check out the Bonneville Club
http://www.bonnevilleclub.com/forum/viewforum.php?f=9
Old 09-11-2006, 11:58 PM
BR57's Avatar
Thumbs up Checked it out - Thanks!
Originally Posted by bastard
good stuff!
