Old 10-16-2006, 02:33 PM
71lemanssprt's Avatar
71lemanssprt 71lemanssprt is offline
do you have the cylinder heads still on if so fill cylinder bores with oil and pull the pushrods leaving the spark pluggs in . this wil create hydraulic lock. if none of the above are possible try bar thru flywheel hole the turn engine till bar locks against block. good luck
Old 10-16-2006, 03:26 PM
Old Goat 67's Avatar
A lenght of rope in one of the cylinders will work also. Just be sure to leave the end sticking out.
Charles
