Old 11-13-2006, 01:28 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
A low MPH and a low ET means the car hooks good.
What's your 60ft. times?
Usually when you spin you'll MPH good but your et will be crappy.
Old 11-13-2006, 02:25 PM
Bruce K Bruce K is offline
In my "vast" experience, lol, better 60', better et and mph.
'79 T/A 6.6 4-sp, 3.23 , 463" E-heads, 252/262 hyd roller, TII, Holley 830, 8.384 @ 93.86 - 1/8, 12.5 @ 116 - 1/4, 2.035 60', 3800 lbs. w/o driver
Old 11-13-2006, 05:27 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Default Hooking better is part...
In my Ventura I was netting a 106.54 MPH, with a 60' in the 1.997 range, ET12.991. After swapping the gears from 3.70 to 4.30 I was running between 104.78 to 105.5 MPH, with a 60' 1.864 to 1.90 range, and ET 12.60
We were worried the lower gear would cause alot more MPH but it actually helped the 60', lowered the MPH, and did raise the RPM from 5000-5100 to around 5600-5700 at the finish line. See the raise in RPM was way less than most people predicted. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
