Old 11-20-2006, 03:00 PM
Chris Stuva Chris Stuva is offline
Default 67 pontiac rear axle swap info?
I have a 67 lemans with a bad rear end. I found a 69 olds 442 rear in good condition. They guy tells me it "should fit". Has anyone every looked into this swap before? If it was a 69 gto I have read it would work, but I don't know about the olds.
Old 11-20-2006, 03:07 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Pretty darn sure it will fit.
I have a Olds rear...10.5 rear ....In my 67. Bolted in just fine..Mine is out of a 71 Cutlass. Very strong rear with bolt in axels too.
........I'm just learning as I go.......
Old 11-20-2006, 03:23 PM
engineer engineer is offline
all A body rears basically interchange from 64-72. Slight differences in width, yoke, and depth, but all bolt in.
Old 11-20-2006, 03:34 PM
Rugratman's Avatar
Forgot to mention I had to shorten my driveshaft a bit to fit though...
Oops, I am late. Is it a 10.5 rear?
Old 11-20-2006, 05:43 PM
baron_ baron_ is offline
Send a message via AIM to baron_
might be an inch wider
meaning you'll have a little less room for thick tires out back, but i don't see any other horrible issues
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Old 11-20-2006, 10:12 PM
Cammer-6 Cammer-6 is offline
64-5 is narrower
66 up is same width
