Have a friend that just gave me a 73 400 with press in 2.11/1.66 4x in decent shape ( spun rod being) with performer intake edelbrock carb hei dist.I am looking for mild to warm street performance in my 71 lemans sport ( storing the orignal 455) this is a aut car with posi track and rear gears in the 3.73 range I think any help would help thks matthew
too much gear with an auto. use 3.55 or 3.23 with Turbo 400. what cam do you have?
was hoping someone would recomend one . not wanting to go completely wild with this motor but want better than stock. also have headers
Why would a 3:73 be too much gear for a TH400? I am currently rebuilding mine and I was looking at going to a 3:73 Posi as I have 3:23 in it now
http://s180.photobucket.com/albums/x...t=21970dbc.pbw http://s180.photobucket.com/albums/x...t=10fd31d1.pbw http://s180.photobucket.com/albums/x...t=f1a25a49.pbw There are no laws against being in love with a Goat.....Right??
Well you could go with an XE274 cam, a set of ported D ports from one of the Pontiac gurus, an RPM intake (fits under the hood ok) Cliffs Qjet, and a nice set of headers.. that would make for a nice healthy 400 that has plenty of driveability and enough power to be fun.
A 400 high stall converter would work pretty well, and they are cheap. Or you could go with another one with a stall of around 2200-2400, I prefer a bit less gear for a driver. I dont often go over 3.55s, and I wont run a mild 455 with any more than that ever again. Most of my drivers keep the 3.08 area gears and I just build more torque for them, keeps the revs down on the highway. |
First thing to do is to double-check the type of 4X heads you are using by checking the stamp on the underside of the boss by the #8 exhaust port.
Unfortunately for me, I have the 4X-4H 98cc, which are small valved (1.96/1.66) and were rated at 150HP for 2 barrel automatics, and (I'm guessing here) 175HP with a 4-barrel. (Those factory ratings would be at the crank, right??) I was hoping that maybe the heads had been improved by the previous owner/builder, but a) being able to run cheap gas, and b) dyno results; indicate stock cc's and valves. Good news is my combo did make 200RWHP/272RWTQ on the dyno. So a head swap is definitely in my future. I'm looking for advice on how to get this combo to 400HP but I don't want to hijack this thread, so I'll start another with combo details. ...unless someone asks...
1981 Trans Am - Dark Maple Metallic 1976 Pontiac 455(462), Kauffman Northwind Intake, Performer RPM Eheads, 11.5:1 compression, Comp Billet Custom cam, Venolia domed pistions, Dougs Headers, Pypes 2.5" Dual Exhaust/X-Over, Solid Body Mounts, GenIV SFCs, FiTech EFI, Walbro 400lph pump, TanksInc. EFI tank. MSD 6AL2, MSD ProBillet. |
