Old 01-08-2007, 12:40 PM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
Default NHRA new taillight rule
Get this.
Taillights must be on every run.
The 07 book says functional taillight but look in National Dragsters rule rev. section, later this year, to change that to read functioning.
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 01-08-2007, 12:58 PM
Ron's Avatar
Ron Ron is offline
That sucks.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 01-08-2007, 01:18 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
1 or 2 on a door car?
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 01-08-2007, 01:24 PM
Ron H's Avatar
Ron H Ron H is offline
Can it be a marker light or must it be tail lights? I am planning on running a Pontiac emblem in the gasdoor and the 2 on the side of my quarters. Will they accept this?
68 Firebird
Are you running with the wind or breaking it?
Old 01-08-2007, 01:32 PM
If it can be seen at the end of the track/turn off by the tower or starting line, it'll be OK.
Old 01-08-2007, 02:06 PM
grandville455's Avatar
Is that for a certain time?speed? or everyone
Darby
M/T 275/60 ET SS Drag Radial
Old 01-08-2007, 02:16 PM
Ron's Avatar
Ron Ron is offline
Everyone.
There will be a number of sportsman racers that will have dead batteries because of this new rule. I don't understand the reasoning to implement such a rule.
New diaper rule will also suck for those with stock front stubs.
Old 01-08-2007, 03:04 PM
fasteddy's Avatar
fasteddy fasteddy is offline
I guess it would be best to just hook 'em up to the hot side of the ignition. Watch Painless Wiring and Moroso come out with a taillight kit real soon. LOL
fasteddy
Old 01-08-2007, 05:14 PM
FBNRacing's Avatar
FBNRacing FBNRacing is offline
I always wire a car with two electric fuel pumps in the back. Each pump has its own switch, fuse and wire. I feed one tail light bulb of each circutt. This way if we lose a pump, we should be able to get down the track on one pump. I being the anal crewchief i am will see we have a problem before he even gets back. I think you will find a standard tail light bulb dont use that much power. If really concerned i think someone makes a series of diodes that wont.
Rex
Old 01-08-2007, 06:05 PM
Sicbird Sicbird is offline
If you're that worried about a couple amps, use LED lamps... They use a fraction of the current draw an incandescent uses, plus they're brighter and vibration resistant.
http://www.superbrightleds.com/tail-brake-turn.html
Old 01-08-2007, 06:39 PM
SlowSpitzer's Avatar
SlowSpitzer SlowSpitzer is offline
I use LED, works good and will last longer than standard bulb.
Guess have to turn it on, all of the IHRA tracks that I g went NHRA, Tri-State, Norwalk and Muncie all went NHRA this year.
Steve
Yea, I know, the heads suck!
2005 Cordova Q16 Winner!
2005 Norwalk Sat Top ET Winner!
Old 01-09-2007, 10:11 AM
J H Performance J H Performance is offline
I have always wired mine so it's on anytime the master switch is, this keeps me from forgeting to turn it on. I seen a crash a few years ago, the track lighting was poor and the guy did'nt have a light on, and they sent the next pair. Lucky no one was seriously hurt, but both cars were damaged.
Old 01-09-2007, 01:14 PM
Originally Posted by Ron
Everyone.
not till 2008 for ET racers
NHRA tech.
Old 01-09-2007, 02:11 PM
60man's Avatar
60man 60man is offline
The rules aren't very clear.....what's new..
When in doubt...go over kill and forget it!
I'll just wire to my fuel pump relay in trunk or ignition toggle switch on main panel.
Done and over with..it is a rule to protect our A$$..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 01-09-2007, 08:31 PM
Everyone.
I can't see how one light bulb will run the battery down.
Steve
Old 01-09-2007, 08:41 PM
Ron's Avatar
Ron Ron is offline
I don't worry about the new rule. My concern is for the casual racer or novice racer. That person will in all likely hood leave his lights on between rounds. It more than one light bulb in a door slammer that is more or less stock and driven on the to the strip.
Old 01-09-2007, 10:28 PM
I was thinking about that I will be unplugging the headlights atleast while I am there,maybe hang a sign in the car on the dash saying check lights,lol...
Darby
Old 01-09-2007, 11:12 PM
goquick's Avatar
goquick goquick is offline
The reason for the light rule is so they can justify keeping the slow down and return roads too dark and not put up the lights that should be in place for the tracks. It's called passing the buck and responsibility to the racer instead of where it belongs.
Old 01-10-2007, 01:13 AM
Old Man Taylor's Avatar
Now there's a man that thinks like I do!
Old 01-14-2007, 09:09 PM
boosted1 boosted1 is offline
i just took the tech test yesturday the tail light does not have to be on during the day
