The reason for the light rule is so they can justify keeping the slow down and return roads too dark and not put up the lights that should be in place for the tracks. It's called passing the buck and responsibility to the racer instead of where it belongs.
Now there's a man that thinks like I do! |
i just took the tech test yesturday the tail light does not have to be on during the day
Took all of 5 minuets to tie DS tail light to fuel pump relay in the trunk. It comes ON when the fuel pump is ativated. If you're anal about tail light being on in the daylight...just unplug tail light from relay wire..NO BIG DEAL. If you have a driver car.....just plug it back in wiring harness when done racing..
At any rate...it's one more thing I don't have to worry about when I'm straped in and can't reach the headlight switch...then what ??
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. Last edited by 60man; 01-15-2007 at 12:32 AM. |
So when are the tracks or nhra going to require the tracks to be lit in the slow down areas and return roads? Anyone? They have yet to return an email when I've asked them.
At some tracks I have been to I wonder what the rails and other fast rides do after the finish line...with no headlights ??? I'm just merely saying it ain't no big deal to comply...what the devil is 5 minuets. While we're on the subject. Seems to me the tracks ought to have a "eye" on the turn off to make sure the cars are clear.....the tower is a LONG way away..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
boosted1, what div was that for? (5?) NHRA ?
Div 3 NHRA requires it to be on all the time, day or night.
I've raced on outlaw tracks that are better lit than nhra tracks after finishline and on return roads. So it could be done. My personnal opinion is this rule is an excuse to keep from accepting any responsibility for conditions at the track. I can promise you that if they were concerned about seeing all of the track, and shutdown areas, the tower would be moved to mid track instead of at the starting line or behind the burnout box so the smoke always blocks their view.
Anyone want me to design a racer AND officals friendly dragstrip? I have alot of ideas that needs a home. I can promise my design will make it more exciting for everyone including the fans.
