Old 01-30-2007, 10:37 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
The heads will fit the 455. But with common flat top pistons, the compression will be about 11:1 to 11:5 so if you want to run pump gas, it will be too high. Might look into a dish piston for that setup. Thanks for saving that T/A.
Old 01-31-2007, 01:03 AM
70RamAirIIITA's Avatar
70RamAirIIITA 70RamAirIIITA is offline
Thank you for the information; I seem to remember reading somwhere that if you put 400 heads on a 455 that the CR would be pretty high. It will be mainly street-driven so if that combination comes together, I'll be sure to get dished slugs. I'm having a helluva time tracking down the WS block, so I figure if I can at least have the correct heads..............I just think the 455 has more potential as far as punching it out. Am I correct in that the 455 has more low-end torque than the 400? What kind of affect will putting the 12's on a 455 have?
As far as saving the T/A, wait until I post pictures of it, it's enough to make you cry. Hmmm, let's see, molded rear fender flares, diamond tuck interior..................needless to say it's going to take a lot of work, but it will be well worth the journey of bringing the Phoenix back to life!
