Old 02-08-2007, 04:59 PM
PaulPaladin PaulPaladin is offline
Default Is this cam a mistake?
'67 Firebird 400 Convertible, TH400, 3.08 rear. Engine being rebuilt by local engine builder. It's the original 400 with "670" heads. Rebuild includes balancing and blueprinting, some modest head work. Maintain stock 10:1 compression.
I want something a "little" hotter than stock, but not radical. Will be totally street driven and not raced. I was thinking a Summit 2801 or the "068" RAIII Crane blueprint with 1.65 rockers.
The builder suggested a Comp Cams PB280AH-10 (Part# 51-314-4).
Installed @ 106 centerline
Duration @ .050 Intake-232 Exhaust-237
Gross valve lift: Intake-.481 Exhaust-.481
LSA - 110
Is this too much cam? He insists it's not. From what I've read I'm worried. Should I be?
1966 GTO Hardtop, Montero Red, '66 "YS" block 389, '67 "670" heads, TH350 (replaced original P'glide), 3:23 open rear.
1967 Firebird 400 Convertible, original "YT" block 400, TH400, factory a/c, Verdoro Green
Old 02-08-2007, 05:03 PM
Thumbs down
LSA - 110
For a 400 engine in a heavy convertible with auto trans and 3.08 gears, a horrible cam choice.
Only if you had 3.90 gears and a converter that stalls at about 2500 it would be a good cam.
Both of the cams you picked would be right on the money.
Old 02-08-2007, 05:17 PM
JKGTO's Avatar
JKGTO JKGTO is offline
Yeah forget that comp grind. Go with the 068 spec cam and put on a mandrel bent exhaust system. Then get a Qjet done by Cliff and you will be very happy with it. Jim
74 LEMANS GT 350 4SPD MAROON
Old 02-08-2007, 05:24 PM
screamingchief's Avatar
I agree,the comp is too big.
Use the 068 blueprint,the 2801 is NOT an 068 "with more lift",they're quite a bit different cams,overlap,LSA,and the timing events are all quite a bit different,dont be mislead by those who tell you otherwise,look at the cam cards/specs.
If you want more lift with the 068,use 1.65 rockers.
The 2801 is actually "smaller" than the 068 (the 2801 is between the 067 and the 068 if you ask me),and with the 670 heads the 2801 will be marginal IMO,ask me it has the potential to build excessive cylinder pressure in a combo like yours.
JMO.
This space for rent...
Old 02-08-2007, 06:24 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
LSA - 110
"Is this too much cam? He insists it's not."
Does this guy know ANYTHING about Pontiacs or is he just a Chevy guy?
"XE cam basher"
Old 02-08-2007, 10:36 PM
Sporter's Avatar
Sporter Sporter is offline
Personally, I'd keep the cam, add Rhoads lifters and swap your crank for a 3" main 4.21" stroke crank. You'll love the torque.
And don't forget the dished pistons.
1967 Firebird ragtop, 464, Weiand 8-71, ported 6H heads, Hyd roller, 4L80E, paddle shifter, Moser 9", Cal-Tracs, Vintage Air, Corbeau seats, 13"/12" disk brakes, Hydraboost, electric cutouts and M&H drag radials.
Old 02-09-2007, 01:28 AM
Will Will is offline
I'd run the Summit 2802 or Crower 60916 and a high quality 2400-2600 stall converter. Those are the absolute biggest cams I'd run in your combo.
Old 02-09-2007, 04:09 AM
I'm going by his shop and telling him I want to go a little more mild and suggest the Crower 60916. I talked to Cliff yesterday and he was a huge help.
Thanks.
Old 02-09-2007, 10:58 AM
8point 8point is offline
Send a message via ICQ to 8point
Paul, I have the same car as you and I built my'n the way Cliff suggested and I am very happy with the results. Most impotent is to 0-deck the block.
My car runs 185 DEG all day long on 91 octane. If you have any other questions let me know. [email protected]
http://photobucket.com/albums/v31/goodbird67/
