WELCOME!
Old 02-20-2007, 08:48 PM
gto1967's Avatar
gto1967 gto1967 is offline
Default Government Opens Investigation Into GTO Defect
http://www.newsnet5.com/news/11066300/detail.html
"An over torqued bolt is already half broken"
Old 02-20-2007, 09:07 PM
Andretti's Avatar
Andretti Andretti is offline
Sounds like a tire size/rim offset issue. You would think this would have been found very early on in testing-production.
I do know tires of the same size from different manufactures can have different outside diameters. Another cause could be different speed ratings affecting high speed dimensions.
Old 02-20-2007, 10:10 PM
455HOGT37's Avatar
455HOGT37 455HOGT37 is offline
Strut rub - Old news. I guess enough people complained that somebody figured out that they should fix it. Simple front end alignment seems to be the fix for the cars that have the problem.
Old 02-21-2007, 04:21 PM
Jeff R's Avatar
Jeff R Jeff R is offline
A front end alignment will fix it, but I'm sure there are a lot of owners who aren't aware there may be a problem. To many people a car (even a GTO) is just an appliance, and they don't go over everything with a fine-toothed comb as you or I might. It's good this is finally getting attention. Hopefully GM will issue a recall or notice to all owners so it won't go overlooked any longer.
Old 02-22-2007, 08:23 AM
87LC2's Avatar
87LC2 87LC2 is offline
40,000 cars, 65 complaints, 8 blowouts and one crash
Alignment and problem solved.
2006 GTO IBM/Black M6
1969 GTO PHS #'s match sold, good riddence
Featured Vendors
Advertising Info
