Old 02-22-2007, 10:56 AM
scotts66goat scotts66goat is offline
Default 66 verses 67 quarters
what exactly is the difference between the two? I have a 66 and located 67 quarters for it. any help would be appreciated
The only stupid question you ask, is the one you don't. Learn at least one thing everyday.
Old 02-22-2007, 01:05 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
The tail, the shape of the tail is different.
Old 02-22-2007, 01:53 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
skins are the same, but full quarter tops are different/top side next to trunk lid.
Mitch Kunath
Old 02-22-2007, 01:55 PM
can the 67's be used? or will it not look right?
Old 02-22-2007, 02:30 PM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
You would need to spend $$ in bodywork. The 66's is a repro item that I have seen used quite a lot, but they are a little rippley and require bodywork to make them straight. If it were me I would hold off unitl I could get some original 66 quarters w/jam.
Brad
Old 02-22-2007, 10:41 PM
Bob Kazian Bob Kazian is offline
Also, the contour of the repro 66 Quarter Panels in front of the wheel is not correct. The Wheel Opening Molding does not fit correctly to the wheel opening contour in front of the rear wheel.
Bob Kazian
Taylors, SC
[email protected]
Old 02-22-2007, 11:33 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Are the 67's you found 'full' quarters? If so, PM me.
