Old 02-26-2007, 03:28 PM
JT_67Tempest's Avatar
JT_67Tempest JT_67Tempest is offline
Send a message via AIM to JT_67Tempest Send a message via MSN to JT_67Tempest Send a message via Yahoo to JT_67Tempest
Originally Posted by gregneun
While strolling the local, self serve, junkyard today I ran across a Pontiac Motor that is ready to pluck. It's in a 73 Safari Wagon. It has 4C heads on it and a 2 barrel manifold with carb. The motor turns easily. We tried to get the timing cover and ran out of time. We would have had to hold the flywheel since the motor spun to easily to remove the Harmonic balancer bolt. There are 2 broken bolts where we tried to remove the cover, but this is easily fixed.
Here's the best heads up that you can get for a local, low buck motor. A short block will run about $110 + core. Complete carb to pan, flywheel to fan is about 175 + core. Currently it is all there.
If you're interested post again or PM me. I'll let you know which yard it is in.
If you lose interest in this find, I will post the location for other interested locals. I didn't want the heads and I have a spare 1968, 400 block already. The timing cover I'd take, but I have to work. Pontiac blocks leave this yard early.
Good luck,
I think I'll pass and let someone else who might be interested in the engine go for it. Thanks for the information though.
Johnny
Johnny
RIP Dad 7/11/05
1967 Tempest
400 CI Stroked to 455
3 Speed Auto w/ Posi
Old 02-26-2007, 03:57 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Johnny
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
