Old 03-13-2007, 12:54 PM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
Originally Posted by Larry Navarro
the above description raises a thought at the design of the WARRIOR intake in comparison to the Victor. If anyone has seen or used one of these intakes, the runner design resembles a "venturi"; starts out wide at the carb base and progressively funnels down to the head ports.
Perhaps the warrior design is to maximize the velocity of the intake charge.
More than likely plus give a good plenum volume to draw from. Of course it's all about what range you want the engine to run in. On the street it's always about compromise and on the strip you can gear it specifically to run at the intended rpm range through the quarter. You can put a 800hp 283cid in a Impala wagon you just better have a 13 speed Road Ranger tranny behind it to keep it on the top of the curve. (Just being silly folks so lets not go off about a 800hp 283, ok?)
Uneasyrider
“To find yourself, think for yourself.”
― Socrates
“The unexamined life is not worth living.”
― Socrates
“Wise men speak because they have something to say; fools because they have to say something.”
― Plato
