Does anyone have any experience with removing a tilt steering column from a 68 GTO? I am going to be repainting my dash and would like to get it out of the way. Also, is there any way to adjust them in the in/out direction? Mine seems to be about 1/4" too close to the dash. Thanks!
R68GTO 1969 Camaro COPO 427 "RAT'S NEST" |
To remove the column, remove the two nuts at the flange
on the rag joint at the top of the gear box, remove the bolts that hold the flange plate that surrounds the base of the column under the dash from the firewall, and remove the two nuts that hold the column to the bottom of the dash(after the trim plate below the column at the bottom of the dash has been removed.) Unplug any electical connections on the column if it has any and remove the column. There are slots on the bracket that holds the column to the dash that allow adjustment front and back, but be aware that moving the column in relation to the dash changes the gap between the steering wheel and the housing below the wheel on a 68 model. You will probably find that you will be able to adjust the column little if any at all without encountering problems with the wheel rubbing the column shroud. If you have a column shifter instead of a dualgate on the floor, you will need to disconnect the rod from the steering column under the hood that goes to the transmission. There is no shift linkage to disconnect if you have a manual tramnsmission CORRECTION: Come to think of it, the columns that I've worked on where the position that the column was bolted to the dash affected the gap behind the steering wheel were 64's 65's and 66's. I think starting in 67 the lower shaft telescopes and you can move the steering column up and down at the slots where it bolts to the bottom of the dash with no consequence. Last edited by gtohurstjudge; 03-13-2007 at 08:21 PM. |
Thanks for the info! That should be enough info to get me in trouble!
