Old 03-21-2007, 10:29 PM
stuffedfrog stuffedfrog is offline
Default Where do you cut the 67 LeMans console to make room for the dual gate?
I searched the forum and found several comments about how easy it isto cut the straight shift console metal tabs in the shifter hole to accomodate the dual gate shifter--it would be great if somebody could post a pic showing exactly which cuts need to be made. Seems like I read a post that had that pic and where to cut, but I can't seem to find it. I guess maybe if I just lined it all up, I could figure it out, but I don't want to do something stupid if somebody else has done it and knows exactly where to cut--thanks guys.
Old 03-24-2007, 12:31 AM
aw c'mon guys, I know 'bout 100 of you guys have done this little operation--help me out before I butcher a perfectly good console....thanks.
Old 03-24-2007, 10:47 PM
242177P's Avatar
242177P 242177P is offline
I'll measure mine (factory) tomorrow. Let you know...
Old 03-28-2007, 01:53 AM
242177P's Avatar
Lost this thread (thought it was in 66/67 Tech) and I was going to take a pic but my batteries are dead, go figure. Pics to follow.
In the meantime if you look at the two studs that are right by the hole you'll have a good reference point. Using the center of the stud (I'm looking at the underside) the rearmost portion of the hole is 5/8ths of an inch away. LH side of the existing hole is an excellent reference point, as I can still see evidence of it's existence on 2 factory consoles. So that side simply gets extended for a front-to-rear total of 7 7/16". The hole is wider too, but it all comes off of the RH side with the width being 3 3/8".
These measurements are just for the metal top, it only now occured to me that there might be different opening size for the plastic bottom (don't think so, but it never hurts to check?) so I'll definitely revisit this topic.
Old 03-29-2007, 02:18 AM
242177P's Avatar
Here are some pics. The hole in the plastic base is a really odd shape, but it might match what your's already has. Let me know if you need any more measurements.
