Old 03-27-2007, 11:47 PM
stuffedfrog stuffedfrog is offline
Default How do I get into a locked trunk?
No, I'm not hiding from my wife. Just bought a '64 Star Chief as a project for my oldest son's first car. The trunk is locked. I unhooked the backrest part of the rear seat from the bottom at the floor but it still seems firmly attached at the top inside somewhere. I pulled it out enough at the bottom just far enough to stick my skinny arm up in there aways, but it feels all solid, so if I got the seat off, I'm not sure even then I would be able to get into the trunk...what to do? Thanks
Old 03-28-2007, 12:19 AM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
if its like my 66 the rear seat should slid up about an inch to unhook the top of the seat and then it can come forward
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 03-28-2007, 12:38 AM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
PICK THE LOCK...OR PAY A LOCKSMITH
Old 03-28-2007, 12:57 AM
gtome's Avatar
gtome gtome is offline
I think nearly every back seat has clips that just have to be pushed upward to get the back seat out. Just take out the back seat bottom and then from the underside beat it upward with your hands...it should go.
Old 03-28-2007, 01:05 AM
poolhusler8's Avatar
poolhusler8 poolhusler8 is offline
Take the back seat out,then take a 3/8 drive ratchet and a couple of long extensions and a 7/16 socket,unscrew the bolts on the trunk latch and it will open right up.
Old 03-28-2007, 03:49 AM
BVR421's Avatar
BVR421 BVR421 is offline
A 3/8 drill bit to blow thru the tumblers then a big screwdriver to rotate the lock. you will have it open in 3 mins or less
you will need a new lock anyway with no key
Old 03-28-2007, 05:56 AM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
if you work on cars alot i would get a lock out kit and a set a jigglers.
Old 03-28-2007, 03:46 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
remove back seat. get a broom handle. tape a flat head screw driver to the end of it. get a flash light, shine it at the lock mechanism. stick screw driver in and turn clockwise. will open right up. i've done this at least 10 times and its simple.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 03-28-2007, 04:08 PM
MOJO Catalina's Avatar
MOJO Catalina MOJO Catalina is offline
Send a message via AIM to MOJO Catalina
That's the way to go. No Hacking, drilling, screwdriving, etc..
You can then remove the cylinder and either have a locksmith make a key or replace it with a new cylinder that has a key.. Glove box is the same key...
Old 03-28-2007, 05:37 PM
gtoquick's Avatar
gtoquick gtoquick is offline
I have just taken out the glove box lock, and had a key made for that code, then used it to get in the trunk. You will need to have a key made anyway...
Michael Q
57 Chieftan 2 door HT, 64 Grand Prix 4-speed project, 64 GTO project, 65 GTO, 66 GTO, 67 GTO project
Old 03-29-2007, 01:08 AM
Ha! You guys are awesome--I want to try all those ideas, but the last I guess seems maybe the way to go, since I need a new glove box key anyway. Sure did like the broomstick and screwdriver idea--might just do that for the fun of it. Thanks again!
Old 03-30-2007, 01:05 AM
I saw a guy cut sheet rock with a circular saw one time... LOL!
It worked, but what a cloud of dust he made!!!
If you lock yourself out of a car, you can smash the window, call a locksmith or borrow a coat hanger to get in...
My point is, there are many ways to get a job done.
Some make a mess and others get it done cleanly and painlessly with minimal damage to surrounding areas...
The pool of human knowledge is deep and wide, especially amongst the Ponti-Yackers... You did the right thing by waiting to get a few opinions before doing anything else... "Lock-on" dude \m/ *^* \m/
Old 03-30-2007, 09:18 AM
Txbobcat Txbobcat is offline
Carry in your vin# to a GOOD locksmith. He can look up the code for the keys and make you one for the trunk.
Old 03-30-2007, 11:34 AM
3 Deuce 64's Avatar
3 Deuce 64 3 Deuce 64 is offline
Send a message via AIM to 3 Deuce 64
Smile
he he he he 8 < )
I'm sure glad I'm not the only nut on the tree .I did that years ago . My dad came in and asked what in the world I was doing . he said you use a knife ! oh , I knew I did something wrong . It's good to see other people do foolish things too you can laugh at youself then
I like the broom handel I used to use one of those 3 foot screw drivers but i like the broom idea better
Old 03-30-2007, 04:38 PM
sandmanjoe's Avatar
HA,, i seen this guy using a saw on 4 sheets at once... now that was some dust.
