get a new set of Texas T/A mufflers they are refractive just like the Noflowmaster.
www.pro-touringf-body.com |
It seems to me that some don,t understand just how the 2nd Gen cars underbody was desgined, it was not desgined for the normal undercar dual muffeler arrangment, they were made for a single transverse mounted muffeler, no matter if single or duals. This being the case I supose for more rear seat room? who knows, the end reasult is their is little room for a muffler in the normal position in front of the axle, thats why people ( like me) are having ground clearnce issiues ( in my case add 3" exhaust on top of that ) . So keeping this in mind when we shop for exhaust will save a lot of hasle later. hope this helps, BTW I knew I would have clearnce issues beforehand.
Jeff
1973 Super Duty Trans Am 455SD, Auto,White/White, Best Et: 11.39 @118 on Drag Radials 3875# |
The factory original exhaust on the 2nd gens with dual mufflers/resonators were not installed parallel to the ground but rather they were angled or sloped. Visuallize the inlet side being higher than the outlet side for both mufflers.
I believe the sole purpose of installing them as such was to maximize ground clearance on as much of the muffler body as possible. Or, they thought it was esthetically more pleasing when viewed from behind (it does look cool, IMO). My Formula originally came with the transverse muffler, but since 1983 I have always had dual exhaust w/dual mufflers installed similar to the factory angle noted above. I don't ever recall bottoming out. |
I have 3' flowmasters with dual 3" system coming off the headers of my 455 78 bird. I've never had a issue hitting but I have stock spring/ride height.
I used mandrel bent pipes and custom fitted it- time consuming but well worth the effort. |
