Old 04-24-2007, 08:08 PM
Hitman's Avatar
Hitman Hitman is offline
Patrick,
I've never had luck with that posting system. I have found it easier to post them with a host and then use the [img]_____________[/img] feature. I use supermotors.net to host my pictures. It's free. I have never seen a 65 gutted, I cant pull up your pictures. I hope you can get it worked out.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 04-24-2007, 08:38 PM
rknrl69 rknrl69 is offline
3rd time to post pictures here goes again
ID:	89401   Click image for larger version
ID:	89402   Click image for larger version
ID:	89403   Click image for larger version
ID:	89404   Click image for larger version
Old 04-24-2007, 08:39 PM
more pics
ID:	89406   Click image for larger version
ID:	89407   Click image for larger version
ID:	89408   Click image for larger version
ID:	89409   Click image for larger version
Old 04-24-2007, 08:42 PM
Default yeh pics worked
Ok set camera to vga and snap away. The floor pans are neer perfect. There are 2 spots around the drivers seat belt and that is it. As you can see the cowl will need some work. Why could they not spend a little more time to seel the windshield?
More as we move forward.
Patrick
Old 04-25-2007, 03:14 AM
born11bravo's Avatar
born11bravo born11bravo is offline
Patrick:
You've been busy. Good work! It doesn't look that bad really, just keep reminding yourself that once that baby is restored you'll have one AMAZING ride.
Have you ever used a rust inhibitor called Rust Bullet? I'm going to try it on my car I think. I have heard that it is much easier to use than POR-15 because you eliminate the pretreatment step. Basically with Rust Bullet you just clean the area up with a brush, getting all the loose stuff knocked off, and then apply it. Check it out......
http://www.rustbullet.com/Products/A...Automotive.htm
I think you're ahead of me now on your restoration, so I'd better get out to the garage and attempt to keep pace.
Dave
born11bravo
1966 Pontiac 2+2, 421/400, 3.23, street
