Old 04-29-2007, 10:13 PM
fattie fattie is offline
Send a message via AIM to fattie Send a message via MSN to fattie
Originally Posted by stevep
The PCV valve is located behind the intake manifold on the passenger side of the motor in the Valley Pan or Push Rod Cover in a rubber grommet. The rubber plug is a stock 65 item, it did not replace the PCV.
The fuel filter is inside the inlet of the carburator.
One way to set points without a meter is to start the car (after you put the points in) and turn the adjusting screw clockwise until the engine starts to misfire and back off 1/2 turn. That USUALLY will get them real close.
fuel filter inside carb ? i have an ames catalog and it shows a canister type , that looks like it would be under the body somewhere. ill have to take a look in the morning. where can i get good points ? the kind you reccomend , ames has some but there 14 dollars and probaly arent any good. thanks
1965 Catalina 4dr with 389
